I am unable to get past these messages. even after I reformatted the sdcard and reloaded the operating system.
can anyone point me in the right direction to get mi piaware working properly
Chris
[2015-07-23 15:06 EDT] no ADS-B data program seen listening on port 30005 for 181 seconds, next check in 60s
[2015-07-23 15:07 EDT] mlat(2558): Connection to localhost:30005 lost: [Errno 111] Connection refused
[2015-07-23 15:07 EDT] mlat(2558): Reconnecting in 30.0 seconds
[2015-07-23 15:07 EDT] mlat(2558): Beast-format results connection with localhost:30004: [Errno 111] Connection refused
It looks like there isn’t a dump1090 or any decoder working. What is the output of a ps ax |grep dump1090? Are you running the FlightAware image or are you building your own?
Okay, do you have the dongle plugged directly into the Pi, or are you using a powered hub? A quick google search shows that error can be caused by a problem with the USB connection. What is the power rating on the power supply (is it a 2A power supply?)
