Just run the tar1090 install again it will fix it.
Thanks very much, I am good now.
Piaware-web on Ubuntu 20.04 on PC / Oracle VM, CPU temp = 0.0 °C ???
abcd@ubuntu20:~$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 48 bits physical, 48 bits virtual
CPU(s): 1
On-line CPU(s) list: 0
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 24
Model name: AMD Ryzen 3 3200G with Radeon Vega Graphics
Stepping: 1
CPU MHz: 3593.246
BogoMIPS: 7186.49
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 32 KiB
L1i cache: 64 KiB
L2 cache: 512 KiB
L3 cache: 4 MiB
NUMA node0 CPU(s): 0
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled v
ia prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user
pointer sanitization
Vulnerability Spectre v2: Mitigation; Full AMD retpoline, STIBP disabled,
RSB filling
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtr
r pge mca cmov pat pse36 clflush mmx fxsr sse s
se2 ht syscall nx mmxext fxsr_opt rdtscp lm con
stant_tsc rep_good nopl nonstop_tsc cpuid extd_
apicid tsc_known_freq pni pclmulqdq monitor sss
e3 cx16 sse4_1 sse4_2 x2apic movbe popcnt aes x
save avx rdrand hypervisor lahf_lm cr8_legacy a
bm sse4a misalignsse 3dnowprefetch ssbd vmmcall
fsgsbase avx2 rdseed clflushopt arat
You’re running it on hardware it doesn’t recognize. If you can provide a PR to fix it on your hardware, I’m happy to merge that.
Thank you for this.
There was an issue with version number and it was showing “Skyaware unknown version” but after a few minutes it updated to Skyaware 5.0
Hey @abcd567 I want to thank you for the great scripts and tutorial! I have been running my station for over six years and it died, so I had to set up a new one. I used your scripts to install Piaware 5 on Debian and everything went well. I also added a second receiver and set up UAT, too. I’m using a small indoor antenna for the UAT, but I’m going to add an outdoor antenna. I bought a FlightAware antenna for 1090 and have been using it for a couple of years. Hope you’re doing well! Thanks again. Joe
Thank you for the scripts, @abcd567! Really appreciate the ease and automation.
Any plans to add a native 64-bit version for public use, @obj?
I’m happy to take build fixes etc for building on whatever target OS, but at the moment there are no plans to produce prebuilt binaries for anything other than standard 32-bit Raspbian.
Have you had a chance to test and see if your scripts work on Debian 11 (bullseye), which was recently released? I don’t dare upgrade my old PC running these services until we know things actually function. Thanks @abcd567 !!
OS Installation CD (iso) used:
debian-11.0.0-amd64-netinst.iso
Following bash scripts built and installed dump1090-fa and piaware from their source code:
(1) DUMP1090-FA
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-dump1090-fa.sh)"
(2) PIAWARE
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-piaware.sh)"
No luck installing piaware on debain 11 yet
i tried
@suffolk3000
Using the scripts in the first post of this thread / Github, both the dump1090-fa 5.0 and piaware 5.0 got installed without trouble, and are working perfectly well on Debian 11 installed on Oracle VM / Windows 10 PC.
What distro you used?
I used debian-11.0.0-amd64-netinst.iso
What is your CPU?
My CPU is
I used following commands to see details:
abcd@debian11:~$ uname -a
Linux debian11 5.10.0-8-amd64 #1 SMP Debian 5.10.46-4 (2021-08-03) x86_64 GNU/Linux
abcd@debian11:~$ lscpu
CPU(s): 1
Socket(s): 1
NUMA node(s): 1
CPU family: 23
Model: 24
Stepping: 1
CPU MHz: 3593.252
BogoMIPS: 7186.50
L1d cache: 32 KiB
L1i cache: 64 KiB
L2 cache: 512 KiB
L3 cache: 4 MiB
RSB filling
Linux PC 5.10.0-8-amd64 #1 SMP Debian 5.10.46-4 (2021-08-03) x86_64 GNU/Linux
type opcc@PC:~$ lscpu
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 60
Model name: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Stepping: 3
CPU MHz: 1319.191
CPU max MHz: 4000.0000
CPU min MHz: 800.0000
BogoMIPS: 7183.97
Virtualization: VT-x
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
L3 cache: 8 MiB
NUMA node0 CPU(s): 0-7
@suffolk3000
Your distro and cpu seems ok.
Did the script build the piaware package "piaware_5.0_amd64.deb"?
You can check this by following commands:
abcd@debian11:~$ cd piaware_builder
abcd@debian11:~/piaware_builder$ ls
buster jessie piaware_5.0_amd64.deb stretch
changelog package-buster piaware-dbgsym_5.0_amd64.deb
common piaware_5.0_amd64.buildinfo README.md
Jenkinsfile piaware_5.0_amd64.changes sensible-build.sh
pcc@PC:~$ cd piaware_builder
-bash: cd: piaware_builder: No such file or directory
pcc@PC:~$ ls
Desktop Music piaware-repository_5.0_all.deb.2 Templates
Documents piaware-repository_5.0_all.deb Pictures Videos
Downloads piaware-repository_5.0_all.deb.1 Public
For some reason, the script failed to clone the source code folder piaware_builder.
Please run the bash script again.
I am wondering how you got all the following?
root@PC:/home/pcc# sudo dpkg -i piaware-repository_5.0_all.deb
(Reading database ... 141787 files and directories currently installed.)
Preparing to unpack piaware-repository_5.0_all.deb ...
Unpacking piaware-repository (5.0) over (5.0) ...
Setting up piaware-repository (5.0) ...
root@PC:/home/pcc# ls
root@PC:/home/pcc# cd piaware_builder
Desktop Downloads piaware-repository_5.0_all.deb Public Videos
Documents Music Pictures Templates
root@PC:/home/pcc#
Please do NOT use piaware-repository_5.0_all.deb
The bash script does not need it, and it may cause conflict.
First purge the repository:
sudo dpkg --purge piaware-repository
Now run the bash script below.
It will clone the source-code folder “piaware_builder”, build the piaware package, and install it.
Yes silly me i got hold of wrong files
all sorted now
going to add aarch64 now
thanx abcd567
