I had the same problem.
First I had a RasPi2B+ running CUPS and PiHole.
Then I Installed the ADSB-Feeders - this worked, but became lame.
So I bought a Banana Pi M1 (http://www.banana-pi.org/m1.html) and installed ArmBian Buster.
The Installations worked fine till I tried to Install the ADSB-Feeders.
This didn’t work.
Finallly I have re-activated the RasPi for the Feeders, it was simpler than to search the small differences between RaspBian and ArmBian.
OrangePiPC / Armbian Buster
Another tricky way to install ver 3.7.1 packages from Flightaware Repository
UPDATED: Sept 16, 2019 12:55 pm EDT
Change apt source from Buster to Stretch and then install piaware, skyview978, and dump978-fa
After installing piaware & dump978-fa, revert apt source to Buster and then install dump1090-fa
RESULTS:
Item | Installation Status |
Operating Status |
Remarks |
Piaware | OK | OK | - |
dump1090-fa | OK | OK | warning “Detected Kernel usbfs mmap() bug, falling back to buffers in userspace” |
dump978-fa | OK | OK | warning “Detected Kernel usbfs mmap() bug, falling back to buffers in userspac” |
skyview978 | OK | OK | - |
STEP-BY-STEP METHOD
STEP-1: Install piaware skyview978, & dump978-fa
Requires apt-source to be changed from Buster to Stretch
## Change default apt source from Buster to Stretch
pi@orangepipc:~$ sudo cp /etc/apt/sources.list /etc/apt/sources.list_backup
pi@orangepipc:~$ sudo sed -i 's/buster/stretch/g' /etc/apt/sources.list
pi@orangepipc:~$ sudo apt-get update
## 1.1 - Install piaware
pi@orangepipc:~$ wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.7.1_all.deb
pi@orangepipc:~$ sudo dpkg -i piaware-repository_3.7.1_all.deb
pi@orangepipc:~$ sudo apt-get install piaware
Created symlink /etc/systemd/system/piaware.service.wants/generate-pirehose-cert.service -> /lib/systemd/system/generate-pirehose-cert.service.
Processing triggers for rsyslog (8.1901.0-1) ...
Processing triggers for systemd (241-5) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10) ...
## 1.2 - Install skyview978 & dump978-fa
pi@orangepipc:~$ sudo apt-get install skyview978 soapysdr-module-rtlsdr soapysdr0.5-2-module-all
0 upgraded, 49 newly installed, 0 to remove and 21 not upgraded.
Need to get 6174 kB/8226 kB of archives.
After this operation, 30.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
pi@orangepipc:~$ sudo apt-get install dump978-fa
The following NEW packages will be installed:
dump978-fa
Setting up dump978-fa (3.7.1) ...
The user `dump978' is already a member of `plugdev'.
Created symlink /etc/systemd/system/default.target.wants/dump978-fa.service -> /lib/systemd/system/dump978-fa.service.
STEP-2: dump1090-fa
Install fails with apt-source Stretch.
Revert apt source to Buster
## Revert apt source from Stretch back to Buster
pi@orangepipc:~$ sudo cp /etc/apt/sources.list_backup /etc/apt/sources.list
## Install dump1090-fa
pi@orangepipc:~$ sudo apt-get install dump1090-fa
Setting up dump1090-fa (3.7.1) ...
Adding user `dump1090' to group `plugdev' ...
Adding user dump1090 to group plugdev
Done.
Enabling lighttpd integration..
Enabling dump1090-fa: ok
Run "service lighttpd force-reload" to enable changes
Enabling lighttpd integration (stat cache)..
Enabling dump1090-fa-statcache: ok
Restarting lighttpd..
Created symlink /etc/systemd/system/default.target.wants/dump1090-fa.service -> /lib/systemd/system/dump1090-fa.service.
STEP-3: Configure
sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
sudo piaware-config uat-receiver-type sdr
sudo sed -i 's/--device-index 0/--device-index 00001090/' /etc/default/dump1090-fa
sudo sed -i 's/driver=rtlsdr/driver=rtlsdr,serial=00000978/' /etc/default/dump978-fa
pi@orangepipc:~$ sudo reboot
Status: piaware
pi@orangepipc:~$ sudo systemctl status piaware
* piaware.service - FlightAware ADS-B uploader
Active: active (running) since Mon 2019-09-16 16:24:55 UTC; 25min ago
Main PID: 4054 (piaware)
Tasks: 6 (limit: 2072)
Memory: 11.9M
|-4054 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
|-4067 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104
|-4070 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.xxx --lon -79.xxx
`-4903 /usr/lib/piaware/helpers/faup978 --connect localhost:30978
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Receiver status: connected
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Server status: synchronized with 114 nearby receivers
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Receiver: 179.6 msg/s received 73.4 msg/s processed (41%)
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.5kB/s UDP to server
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Results: 63.7 positions/minute
Sep 16 16:39:58 orangepipc piaware[4054]: mlat-client(4067): Aircraft: 26 of 49 Mode S, 24 of 41 ADS-B used
Sep 16 16:40:30 orangepipc piaware[4054]: 5274 msgs recv'd from dump1090-fa (1576 in last 5m); 5274 msgs sent to FlightAware
Sep 16 16:40:30 orangepipc piaware[4054]: 0 msgs recv'd from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
Sep 16 16:45:30 orangepipc piaware[4054]: 6491 msgs recv'd from dump1090-fa (1217 in last 5m); 6491 msgs sent to FlightAware
Sep 16 16:45:30 orangepipc piaware[4054]: 0 msgs recv'd from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
Status: dump1090-fa
pi@orangepipc:~$ sudo systemctl status dump1090-fa
* dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
Active: active (running) since Mon 2019-09-16 16:15:35 UTC; 36min ago
Main PID: 768 (dump1090-fa)
Tasks: 3 (limit: 2072)
Memory: 12.3M
`-768 /usr/bin/dump1090-fa --device-index 00001090 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 360 --net --net-heartbeat 60 --net-ro-
Sep 16 16:15:35 orangepipc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Sep 16 16:15:35 orangepipc dump1090-fa[768]: Mon Sep 16 16:15:35 2019 UTC dump1090-fa 3.7.1 starting up.
Sep 16 16:15:36 orangepipc dump1090-fa[768]: rtlsdr: using device #1: Generic RTL2832U (Realtek, RTL2832U, SN 00001090)
Sep 16 16:15:36 orangepipc dump1090-fa[768]: Detached kernel driver
Sep 16 16:15:36 orangepipc dump1090-fa[768]: Found Rafael Micro R820T tuner
Sep 16 16:15:36 orangepipc dump1090-fa[768]: rtlsdr: enabling tuner AGC
Sep 16 16:15:36 orangepipc dump1090-fa[768]: Allocating 4 zero-copy buffers
Sep 16 16:15:36 orangepipc dump1090-fa[768]: Detected Kernel usbfs mmap() bug, falling back to buffers in userspace
Status: dump978-fa
pi@orangepipc:~$ sudo systemctl status dump978-fa
* dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2019-09-16 16:30:19 UTC; 22min ago
Main PID: 4876 (dump978-fa)
Tasks: 4 (limit: 2072)
Memory: 4.3M
CGroup: /system.slice/dump978-fa.service
`-4876 /usr/bin/dump978-fa --sdr driver=rtlsdr,serial=00000978 --format CS8 --raw-port 30978 --json-port 30979
Sep 16 16:30:20 orangepipc dump978-fa[4876]: Detached kernel driver
Sep 16 16:30:20 orangepipc dump978-fa[4876]: Found Rafael Micro R820T tuner
Sep 16 16:30:20 orangepipc dump978-fa[4876]: Exact sample rate is: 2083333.135571 Hz
Sep 16 16:30:20 orangepipc dump978-fa[4876]: [R82XX] PLL not locked!
Sep 16 16:30:20 orangepipc dump978-fa[4876]: SoapySDR: using maximum manual gain 49.6 dB
Sep 16 16:30:20 orangepipc dump978-fa[4876]: SoapySDR: using stream setting buffsize=262144
Sep 16 16:30:20 orangepipc dump978-fa[4876]: Allocating 15 zero-copy buffers
Sep 16 16:30:20 orangepipc dump978-fa[4876]: Detected Kernel usbfs mmap() bug, falling back to buffers in userspace
Sep 16 16:30:48 orangepipc dump978-fa[4876]: [::]:30978: accepted a connection from [::1]:36078
Sep 16 16:30:49 orangepipc dump978-fa[4876]: [::]:30978: accepted a connection from [::1]:36080
Station 76000:
1090Mhz: OrangePiPC + ProStick Plus + FA Filter + FA Antenna (indoor in a window)
978 MHz: OrangePiPC + Generic DVB-T with it’s mag-mount whip antenna in window
At a glance you didn’t install any soapysdr driver modules.
I think it was installed. Please see this.
I have slipped out test microSD card and now regular microSD card (Armbian Stretch) is in the Orange Pi. Will tomorrow morning check if it was actually installed
apt-cache policy libsoapysdr0.5-2
That’s the soapysdr base library, not a driver. You need at least one driver, e.g. the rtlsdr module. There is a Recommends: dependency in the dump978 package:
Recommends: skyaware978, soapysdr-module-rtlsdr
Thanks for guidance. I am away from OrangePi, so will install missing module tomorrow after slipping-in the test microSD card.
sudo apt-get install soapysdr-module-rtlsdr
Realized that I have missed the recommended packages for dump978.
Purged skyview978 & dump978-fa, then did following, and now all is working OK.
Updated my post accordingly.
The following additional packages will be installed:
libsoapysdr0.5-2
Recommended packages:
skyview978 soapysdr-module-rtlsdr soapysdr0.5-2-module-all | soapysdr0.5-2-module
dump978-fa libsoapysdr0.5-2
Do you want to continue? [Y/n] n
Abort.
libairspy0 libasyncns0 libboost-atomic1.62.0 libboost-chrono1.62.0 libboost-date-time1.62.0
libboost-serialization1.62.0 libboost-test1.62.0 libboost-thread1.62.0 libboost-timer1.62.0 libflac8 libhackrf0
libhamlib2 libice6 libjack-jackd2-0 liblimesuite16.12-1 libogg0 libopus0 libpulse0 librtaudio5a libsm6 libsndfile1
libsoapysdr0.5-2 libuhd003 libusb-0.1-4 libvorbis0a libvorbisenc2 libx11-6 libx11-data libx11-xcb1 libxau6 libxcb1
libxdmcp6 libxext6 libxi6 libxtst6 multiarch-support soapysdr0.5-2-module-airspy soapysdr0.5-2-module-audio
soapysdr0.5-2-module-bladerf soapysdr0.5-2-module-hackrf soapysdr0.5-2-module-lms7 soapysdr0.5-2-module-redpitaya
soapysdr0.5-2-module-remote soapysdr0.5-2-module-rtlsdr soapysdr0.5-2-module-uhd x11-common
Suggested packages:
jackd2 opus-tools pulseaudio gnuradio
limesuite-udev
libxdmcp6 libxext6 libxi6 libxtst6 multiarch-support skyview978 soapysdr-module-rtlsdr soapysdr0.5-2-module-airspy
soapysdr0.5-2-module-all soapysdr0.5-2-module-audio soapysdr0.5-2-module-bladerf soapysdr0.5-2-module-hackrf
soapysdr0.5-2-module-lms7 soapysdr0.5-2-module-redpitaya soapysdr0.5-2-module-remote soapysdr0.5-2-module-rtlsdr
dump978-fa
Unpacking dump978-fa (3.7.1) ...
Ver 3.7.2
Installation of piaware, dump1090-fa & dump978-fa pre-built packages on OrangePiPC / Armbian Buster
pi@orangepipc:~$ uname -a
Linux orangepipc 4.19.59-sunxi #5.91 SMP Mon Jul 15 14:09:32 CEST 2019 armv7l GNU/Linux
pi@orangepipc:~$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
1 - Prepare repository
wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.7.2_all.deb
sudo dpkg -i piaware-repository_3.7.2_all.deb
sudo apt-get update
2 - Install dump1090-fa
sudo reboot
3 - Change apt source from default Buster to Stretch
Installation of piaware & dump978-fa fails with default apt-source Buster
Requires apt-source to be changed to Stretch
sudo apt-get update
4 - Install piaware
5 - Install dump978-fa & skyaware978 (Optional, for USA only)
## 5.1 - Install required dependencies
sudo apt-get install skyaware978 soapysdr-module-rtlsdr soapysdr0.5-2-module-all
## 5.2 - Install dump978-fa
6 - Restore apt source to Buster
sudo apt-get update
7 - Configure
sudo reboot
8 - Check Status piaware
Active: active (running) since Sat 2019-09-21 21:45:31 EDT; 42s ago
Main PID: 1322 (piaware)
Memory: 11.4M
|-1322 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
|-1334 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,lo
|-1337 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.xxx --lon -79.xxx
`-1340 /usr/lib/piaware/helpers/faup978 --connect localhost:30978
Sep 21 21:45:35 orangepipc piaware[1322]: mlat-client(1334): Input connected to localhost:30005
Sep 21 21:45:35 orangepipc piaware[1322]: mlat-client(1334): Input format changed to BEAST, 12MHz clock
Sep 21 21:45:35 orangepipc piaware[1322]: faup978(1340): Connecting to localhost:30978
Sep 21 21:45:35 orangepipc piaware[1322]: faup978(1340): Connected to [::1]:30978
Sep 21 21:45:35 orangepipc piaware[1322]: piaware received a message from dump1090-fa!
Sep 21 21:45:35 orangepipc piaware[1322]: mlat-client(1334): Beast-format results connection with ::1:30104: connection established
Sep 21 21:45:36 orangepipc piaware[1322]: mlat-client(1334): Accepted Beast-format results connection from ::ffff:192.168.0.10:62474
Sep 21 21:45:36 orangepipc piaware[1322]: piaware has successfully sent several msgs to FlightAware!
Sep 21 21:46:06 orangepipc piaware[1322]: 113 msgs recv'd from dump1090-fa; 113 msgs sent to FlightAware
Sep 21 21:46:06 orangepipc piaware[1322]: 0 msgs recv'd from dump978-fa; 0 msgs sent to FlightAware
9 - Check Status dump1090-fa
Active: active (running) since Sat 2019-09-21 21:42:47 EDT; 5min ago
Main PID: 1286 (dump1090-fa)
Memory: 6.0M
`-1286 /usr/bin/dump1090-fa --device-index 00001090 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 360 --net --net-heartbea
Sep 21 21:42:47 orangepipc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Sep 21 21:42:47 orangepipc dump1090-fa[1286]: Sat Sep 21 21:42:47 2019 EDT dump1090-fa 3.7.2 starting up.
Sep 21 21:42:47 orangepipc dump1090-fa[1286]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001090)
Sep 21 21:42:47 orangepipc dump1090-fa[1286]: Detached kernel driver
Sep 21 21:42:47 orangepipc dump1090-fa[1286]: Found Rafael Micro R820T tuner
Sep 21 21:42:47 orangepipc dump1090-fa[1286]: rtlsdr: enabling tuner AGC
Sep 21 21:42:48 orangepipc dump1090-fa[1286]: Allocating 4 zero-copy buffers
Sep 21 21:42:48 orangepipc dump1090-fa[1286]: Detected Kernel usbfs mmap() bug, falling back to buffers in userspace
10 - Check Status dump978-fa
Active: active (running) since Sat 2019-09-21 21:41:32 EDT; 7min ago
Main PID: 762 (dump978-fa)
Memory: 17.1M
`-762 /usr/bin/dump978-fa --sdr driver=rtlsdr,serial=00000978 --format CS8 --raw-port 30978 --json-port 30979
Sep 21 21:41:35 orangepipc dump978-fa[762]: SoapySDR: using maximum manual gain 49.6 dB
Sep 21 21:41:35 orangepipc dump978-fa[762]: SoapySDR: using stream setting buffsize=262144
Sep 21 21:41:35 orangepipc dump978-fa[762]: Allocating 15 zero-copy buffers
Sep 21 21:41:35 orangepipc dump978-fa[762]: [::]:30978: accepted a connection from [::1]:46240
Sep 21 21:41:35 orangepipc dump978-fa[762]: Detected Kernel usbfs mmap() bug, falling back to buffers in userspace
Sep 21 21:41:42 orangepipc dump978-fa[762]: [::]:30978: accepted a connection from [::1]:46244
Sep 21 21:42:47 orangepipc dump978-fa[762]: [::1]:46240: connection closed
Sep 21 21:42:47 orangepipc dump978-fa[762]: [::]:30978: accepted a connection from [::1]:46246
Sep 21 21:45:30 orangepipc dump978-fa[762]: [::1]:46244: connection closed
Sep 21 21:45:35 orangepipc dump978-fa[762]: [::]:30978: accepted a connection from [::1]:46258
Ver 3.8~dev on Armbian Buster / OrangePiPC
For Armbian Buster, the piaware ver 3.8~dev does not have issue of dependencies. Here is the procedure I took to do this:
Linux orangepipc 5.3.9-sunxi #19.11.3 SMP Mon Nov 18 18:49:43 CET 2019 armv7l GNU/Linux
(1) dump10909-fa
The package install works fine. No need to build it from source code
sudo apt-get update
sudo reboot
(2) Piaware
Package install fails. Build from source-code
2.1 - Install dependencies
sudo apt install debhelper tcl8.6-dev python3-dev python3-venv libz-dev dh-systemd
sudo apt install tcl tclx8.4 tcllib tcl-tls itcl3 libboost-system-dev
sudo apt install libboost-program-options-dev libboost-regex-dev libboost-filesystem-dev
2.2 - Clone source-code, checkout to dev version, and build the package
git clone https://github.com/flightaware/piaware_builder.git
cd piaware_builder
git checkout dev
./sensible-build.sh buster
cd package-buster
sudo dpkg-buildpackage -b
cd ../
sudo dpkg -i piaware_3.8.0~dev_armhf.deb
2.3 - Configure
2.4 - Checks what version installed
pi@orangepipc:~$ apt-cache policy piaware
piaware:
Installed: 3.8.0~dev
Candidate: 3.8.0~dev
Version table:
*** 3.8.0~dev 100
100 /var/lib/dpkg/status
3.7.2 500
500 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf Packages
2.5 - Check status
Active: active (running) since Mon 2019-12-23 13:29:47 EST; 25min ago
Main PID: 1001 (piaware)
Tasks: 3 (limit: 2068)
Memory: 9.1M
├─1001 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
└─1198 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.xxx --lon -79.xxx
Dec 23 13:29:51 orangepipc piaware[1001]: Started faup1090 (pid 1198) to connect to dump1090-fa
Dec 23 13:29:51 orangepipc piaware[1001]: UAT support disabled by local configuration setting: uat-receiver-type
Dec 23 13:29:51 orangepipc piaware[1001]: piaware received a message from dump1090-fa!
Dec 23 13:29:52 orangepipc piaware[1001]: piaware has successfully sent several msgs to FlightAware!
Dec 23 13:30:22 orangepipc piaware[1001]: 196 msgs recv'd from dump1090-fa; 196 msgs sent to FlightAware
Dec 23 13:35:22 orangepipc piaware[1001]: 1806 msgs recv'd from dump1090-fa (1610 in last 5m); 1806 msgs sent to FlightAware
Dec 23 13:40:22 orangepipc piaware[1001]: 3496 msgs recv'd from dump1090-fa (1690 in last 5m); 3496 msgs sent to FlightAware
Dec 23 13:45:22 orangepipc piaware[1001]: 5062 msgs recv'd from dump1090-fa (1566 in last 5m); 5062 msgs sent to FlightAware
Dec 23 13:50:22 orangepipc piaware[1001]: 6714 msgs recv'd from dump1090-fa (1652 in last 5m); 6714 msgs sent to FlightAware
Dec 23 13:55:22 orangepipc piaware[1001]: 8320 msgs recv'd from dump1090-fa (1606 in last 5m); 8320 msgs sent to FlightAware
(3) dump978-fa (FAILED)
3.1 - Install build tools & dependencies
sudo apt install build-essential debhelper dh-systemd
sudo apt install libboost-system-dev libboost-program-options-dev
sudo apt install libboost-regex-dev libboost-filesystem-dev libsoapysdr-dev
3.2. Clone source-code, build package, and install package
git clone https://github.com/flightaware/dump978.git
cd dump978
git checkout dev
cd ../
sudo dpkg -i dump978-fa_3.8.0~dev_armhf.deb
3.3 - Configure
3.3.1 - Serialize dongles: (CLICK HERE)
3.3.2 - configure dump1090 and dump978
# Reboot Pi to implement configuration settings
sudo reboot
3.4 - Check status
[sudo] password for pi:
● dump978-fa.service - dump978 ADS-B UAT receiver
Active: activating (auto-restart) (Result: exit-code) since Tue 2019-12-24 14:15:21 EST; 21s ago
Process: 5018 ExecStart=/usr/share/dump978-fa/start-dump978-fa (code=exited, status=2)
Main PID: 5018 (code=exited, status=2)
Hi Guys,
How are the orange Pi PC going? Still recommended?
Cheers
Chris
YES
Yes from me too. Orange Pi PC has been my Piaware feeder for the last 4+ years
Workaround for installing dump978-fa ver 7.0 on OrangePiPC / Armbian Bullseye from my PPA.
The dump978-fa, though got installed, but failed to run. This was due to failure of Armbian’s apt to install dependencies listed under “Recommends:” in package’s file debian/rules
The workaround I did was to install these manually by following command:
sudo apt install soapysdr-module-rtlsdr
sudo apt install skyaware978
sudo systemctl restart dump978-fa
I have compared the /etc/apt/source.list
of Armbian and RaspberryPiOS, and found the difference is as follows:
Armbian points to "deb http://deb.debian.org/debian"
RaspberryPi OS points to "deb http://raspbian.raspberrypi.org/raspbian/"
NOTE: This workaround is not required when installing same package on RPi / RaspberryPi OS Bullseye. Apt automatically installs all required dependencies.
