Most likely it’s a 2.4 GHz WLAN antenna.
/M
/M
…actually, since the VSWR is about 1.02 at about 1840 MHz it’s probably designed for Mobile Communications since the other (legal) possibility of “Space Operations - Ground to Space” would be using a large dish.
Had the same problem with the ebay 9dbi antenna. It does not work at 1090MHZ. Took it apart and here is what is inside.
The supplier refunded my $8.99.
Could you pls disassemble this tube/sleeve to see what’s inside?
It appears to be a solid piece of metal with crimp connection to the antenna wire(s).
My analyzer turned up this afternoon so I got stuck in looking at 2 antennas I’ve made.
The first is a Quad
Here is the SWR and the sweep
https://img2.brain3.photobox.com/988336328de3585adb091f9c5b865978757e2e8ee7e8c93f500163291db93ff73c3741b9.jpghttps://img2.brain3.photobox.com/81446130d2eaa40744f5c93c72a7df46302db4d102e584d896ae5f2b10bf9905a32b879b.jpg
This one is a 12 element CoCo
I don’t understand the sweep graph. Has anyone else done a sweep of a CoCo?
Many thanks
VSWR and Antenna Performance–
(Low) VSWR does NOT indicate good antenna performance! It only tells you about the impedance matching between the antenna and the load (source).
I have a Bird Precision Dummy Load that has a VSWR of under 1.1 from pretty much DC up to around 4200 MHz (while taking 100 Watts) – very flat. Doesn’t “antenna” worth a damn.
VSWR is very important when you’re transmitting. For most hams, anything under 1.3 (or 1.5) is fine. For QRO (high power), yeah, 1.1 is better.
For receiving, the change in VSWR over frequency is more interesting as an indicator of antenna performance. But a VSWR of 2 in a receiving system isn’t the end of the world.
An indication of this is the number of our colleagues who are getting hammered by energy in the 960 MHz region, even though the FA antennas they’re using have a relatively high VSWR at those frequencies.
The noted American RF and Antenna researcher H.L. Mencken summed it up nicely:
For every complex problem, there is an answer that is clear, simple, and wrong.
(ok, he wasn’t an RF and antenna researcher, but his comment holds over many fields of endeavor)
respectfully submitted,
bob k6rtm
Hi Bob,
Many thanks for your sage words. Being a novice at all this antenna stuff, I find it difficult to fathom how the different parameters relate to each other. I’m getting there slowly
Have you done any testing with the N1201SA?
I posted trigger’s question on eHam.net, and got following 3 responses:
RESPONSE #1
RESPONSE #2
RESPONSE #3
Thanks for the responses from eHam.
https://img2.brain3.photobox.com/61637879b5eaf03dfa9e9870e84d63df43210e1eca99adf897609f5281651f27c614c41d.jpg
I’ve done a bit more investigation and found that I get the same response as above, when I just have a length (3m) of coax attached to the analyzer. Is that normal? My coax has no markings on it except SAT 100. I know the VF is 0.66 from building many CoCos
I don’t live in a noisy environment as I’m in the countryside and no masts within 2 km. I do have a Davis weather station which states it transmits by “Frequency-hopping spread spectrum radio”
I’ll do a scan with SDR Sharp or HDSDR this evening.
@triggers:
The plot for Keith’s commercial Moonraker aerial is similar to your Coco’s plot. He has posted it on page 2 of this thread:
The Davis Wx station should be TX’ing on 868MHz every 2.5 seconds if it’s a UK model (I have a UK VP2).
I don’t notice it on 1090
Nigel.
Thanks for your input. I thought the frequency would be well away from 1090Mhz but I wasn’t sure. It is a UK model.
I get the same “fuzz” everytime when I stick any length of RG-6 between the antenna and analyzer. Swap it out with LMR400 or whatever and it’s fine again. Mismatch throws the thing for a loop.
I have posted trigger’s question in the forum “ham.stackexchange.com”. Answers are slowly pouring in.
Mine has been ordered, last message was being shipped out this week, cant wait to give it a test on a few I made up.
Hello, did anyone test this antenna with the N1201 SA. Thank you
Huge long delay before replying. The correct way to turn it on is to hold the CTRL button and tap the OK button and then release the CTRL button. That has never failed for me.
