Here you go. FYI I have maxed out the gain again to -10.
Traffic is quiet now so tomrrow I will run the gain optimisation script and see what the figures say. It will probably all change again when I install the new filter ![]()
Just for comparison iโve changed today my gain from 49.6 to 43.4
Graphs below the change was at 16:20 where you can see the peak in the tracks graph.
Doesnโt have that much impact, but maybe because i am using the blue 1090MHz filter between dongle and antenna
The downtrend of aircraft is normal on a typical Saturday with less recreation flights
Looks good. I cant post the 8 hour chart yet as I still have huge peaks from earlier. Really need to place my antenna on the chimney, not getting much distance to the north due to obstacles ![]()
As said you seem to have a very low traffic in your area. So the deviation will be significant.
I would make only small adjustments until the numbers are going up the next couple of weeks again.
