Java library?
#1
Hi, I want to use the flightxml2 api using java, there are two examples in the documention that let me think there is a java library available, but i can’t find it…
(“import com.flightaware.flightxml.soap.FlightXML2.*;”)
So is there one, and if so, where could I find it?
EDIT : I guess the link “http://flightxml.flightaware.com/soap/FlightXML2/wsdl” may be the repository of the library in xml. If it is, how can I turn it into a .java?
Thank you for your time
#2
The documentation page at flightaware.com/commercial/fligh … ation2.rvt has a couple of Java examples at the bottom of the page using Axis1 and Axis2. Using the “wsdl2java” utility that comes with Axis, you can generate the java class library that represents the methods and structures defined within the WSDL file.
