I can’t see a single advantage in dump1090-mutability besides maybe liking the web interface with the clocks and minimalistic design.
So i might accept dump1090-fa with the mutability interface, but the other way around?
dump1090-fa is the successor to dump1090-mutability.
The only flightaware thing about it is the webinterface.
(and that it’s maintained by someone who is now forking for FA)
The beast and AVR output formats are on the same ports and are exactly the same.
Unless you have a non-standard configuration you can’t change…
If you are worried about fr24, see this:
It 360radar I don’t want to mess up as this was the first site that got me a little hooked
Well if you don’t understand the settings then maybe it’s best to leave it.
As i said the protocols used are exactly the same.
Hi @abcd567,
I am using your method on Raspbian buster to install the dump1090-fa with gain control.
For the Buster Version:-
sudo apt update
sudo apt install php7.3-cgi
sudo lighty-enable-mod fastcgi-php
sudo /etc/init.d/lighttpd force-reload
It works.
Thanks.
I tried the Piaware 3.7.1 stretch image instructions and got the gain button to show but when I change the gain value and click SET GAIN, the displayed gain value stays at -10 even though dump1090 restarts.
Any ideas what I did wrong?
Dont you see Current Gain: xx.x in red?
EDIT:
Did you reboot?
The Set Gain button wont work unless you reboot after completing the modifications.
Did the reboot and I do see the number in red …
I can change the value …
but when I click SET GAIN, the screen flashes and it returns to the current value of -10.
Open cron:
sudo crontab -e
Scroll down to bottom of the cron file. Do you see following line? If not add it, save file, then reboot
@reboot /bin/bash /usr/local/sbin/gain/setgain.sh
Tried that - the line was already there - is this the correct file name?
YES, if it got opened by command sudo crontab -e
You told what instructions you used, but did NOT tell what is your install
Is your install:
The Stretch instruction wont work on Buster, unless you install php7.3 (Stretch instructions install php7.0)
Piaware SD card image 3.7.1 (which is Stretch based)
Let’s check this:
grep piaware /usr/local/sbin/gain/setgain.sh
And this:
piaware-config -show rtlsdr-gain
echo 40 > /usr/local/sbin/gain/newgain
If the above is working, then the most likely reason is that you somehow didn’t get the gain.php quite right.
First check if php7.0-cgi got installed
apt-cache policy php7.0-cgi
(a) If it shows php7.0-cgi NOT installed, install it by following commands
sudo apt install php7.0-cgi
(b) If it shows php7.0-cgi installed, then do following:
sudo rm /usr/local/sbin/gain/setgain.sh
sudo rm /usr/share/dump1090-fa/html/gain.php
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/set-gain/master/piaware-img.sh)"
NOTE:
When bash script finishes, it will display a set of instructions. Ignore these as you have cron and html hacks already in place.
@abcd567, thanks - that fixed it!
php7.0-cgi was already installed so part (b) was the solution.
Hi!
Just updated to PiAware 5 and edited /usr/share/dump1090-fa/html/index.html but no gain selection shows up anymore on SkyView.
Try these 3 addresse in browser:
IP-of-PI/skyaware/
IP-of-PI/skyaware/gain.php
IP-of-PI/dump1090-fa/gain.php
After trying these adresses
Does changing gain setting in IP-of-PI/dump1090-fa/gain.php
show that gain has changed? If yes, then for the time being manage gain adjustment from this drop down. I will have to study and revise the procedure to suite ver 5.0
