I like the original version better. quick. no hassles. security ? well…
I care for it… I dont want anyone to steal the list of phone numbers of my girlfriends, and my panama offshore account details, which I have stored in my RPi
Actually the new version isn’t any more complicated as far as i can see.
Now as you have already set it up leaving it as is sure is easier.
surely you see it through your IT glasses …
I’m curious what is more complicated with the “new” approach for you?
edit: Oh i get it you mean how the thing works. i thought installing it
Yes the named pipe and stuff is kinda more complicated
oh, just read all the relevant posts and do it again from the beginning. right now it works well, to my taste, so I need to devote time to other stuff. after all “if it works…”.
as I said don’t mind if anybody managed to hack a rpi that ONLY does ads-b stuff. I can leave with that. reformat SD with backup image and all back to normal. (fyi I don’t even have a credit card let alone putting codes etc in there).
Procedure Partly Automated
Applies to following posts:
- Rev-1, Piaware SD card image
- Rev-1, Raspbian image + dump1090-fa
- Rev-1, Raspbian image+dump1090-mutability
The Automated Part:
The scripts executes steps 1, 2, & 3 of above posts
sudo apt install git
git clone https://github.com/abcd567a/set-gain.git
In the cloned folder set-gain
, there are 3 files as listed below:
Use the file which applies to your install.
For Piaware SD card image
cd set-gain
./piaware-img.sh
For Raspbian image with dump1090-fa package install
cd set-gain
./raspbian+dump-fa.sh
For Raspbian image with dump1090-mutability package install
cd set-gain
./raspbian+dump-mut.sh
The Manual Part (After running the script as above)
(1) Execute entire STEP-4 of above posts (i.e. edit the file index.html
or gmap.html
(2) Execute Step 2.3 of above posts, i.e issue command sudo crontab -e
and in file opened, add the line
@reboot /bin/bash /usr/local/sbin/gain/setgain.sh
(3) Finally, Reboot Pi to implement modifications
If you dont want to modify your SkyView Map/Dump1090-mutability Map
You can still set gain from an independent page if you omit step 4 (modifications in SkyView). You have to carry-out steps 1 to 3 only.
The steps 1 to 3 can be executed by auto-install script from github . In addition, issue command sudo crontab -e
and in file opened, add the line @reboot /bin/bash /usr/local/sbin/gain/setgain.sh
Alternatively steps 1 to 3 can be carried out manually as detailed in posts for Rev-1.
You can then get the “Set Gain” Button in an independent page in browser at following address:
IP-OF-PI/dump1090-fa/gain.php
OR
IP-OF-PI/dump1090-mutability/gain.php
Hi guys,
long time I posted here, had no problems
I update my Raspberry Pi today (sudo apt-get update and sudo apt-get upgrade)
I saw that version 3.7.1 of Piaware is now running, so that is good news , I kept the conf file of dump 1090 fa during the update (this question “popped up”) and the “enable” line was added automatically, nice.
I saw that naturally the button on the screen to change the gain was gone (as expected), so my question is : I have just to adjust the index.html file to get it back ?
The gain.php file is still untouched.
Thanks for any advice.
/usr/share/dump1090-fa/html
directory is overwritten on updates.
So depending on what you changed in that directory you are going to have to do that again.
Yes, index.html only. Please do this:
Hi,
made the adjustment, all ok for the moment
Hi,
Looking for a bit of help, using Jessie dump 1090 mutability, getting to step 4.3, but it can’t find sudo_button to insert text, where am I going wrong
The gmap.html you have looks different, it has a newer ol version.
Looks like it’s not original dump1090-mutability.
I’m not sure where you got this version.
That’s dump1090-fa. Not mutability.
Look for the guide for that.
I think this is the updated guide for dump1090-fa package install:
How-to Read / Set Gain from SkyView and Gmap - #104 by abcd567
Skin of Skyview but inside dump1090-mutability ver 1.15~dev (see top-right of aircraft table)
I think this hybrid needs its own method. None of methods given above can work alone.
Use all steps for dump1090-mutability (click here) except STEP-4 (which is for adding button in map). Instead use (STEP-4) of dump1090-fa (click here)
Interesting.
I’d just install dump1090-fa and remove the strange hybrid going on.
The best of both worlds
Cheers for the suggestion, but it came up 403 Forbidden, it was worth a try. I don’t want to change the present install as I don’t know if it will affect other sites I’m feeding to. But thanks again for the help
