@abcd567 When you get a change, change the buildpackage commands like this:
dpkg-buildpackage -b --no-sign
Also … that really doesn’t need sudo unless you used sudo on it before creating files that are not owned by the pi user.
Anyhow … sudo doesn’t matter i guess.
I have 2 x OrangePi PC & 2 x OrangePi Zero H2+ run for years, unfortunately my 2 x OPi Zero H2+ & 1 x OPi PC will hang about every 5-7 days. Left another 1 running without any problem. The 3 Pis’ sd card formatted and re-image to new image also the same, will hang every 5-7 days. Even replace to another new sd card also the same.
To me, the price is reasonable for the boards, can consider to get another 2-3 for extra stocks.
I purchased 1st OrangePiPC in begining of 2016. It worked OK till begining of 2019, then started hanging every few days, and finally died in July 2019. I purchased a new one 6 months ago (August 2019), and the new one is working OK, no hanging yet.
But yours OPi is last longer… May be due to the location as your location is in Canada (Cold), and my location is East Malaysia (North Borneo) a bit warm / hot.
Better go for Raspberry Pi. These are costlier than Orange PI but seem to be more durable.
My RPi Model 2B is running continuously for ADS-B without any issues since mid 2015, almost 5 years now.
Yeah. Consider for more durable, which can last longer.
As we can see that the Flightfeeder provided by FlightAware, running 7/24/365 without any issue.
Better go for the Raspberry Pi.
For the Nanopi K2 (Amlogic S905 CPU), I can install rtl-airband without any problem, so just leave as is for LiveATC purposes.
That’s pretty strange because neither dump1090-fa nor piaware do anything special to the boot process, they’re just normal services that get started along with everything else, and they run as an unprivileged user. Even if they failed to start entirely, I would not expect that to affect your ability to log in to the system etc.
My only guess would be that dump1090-fa’s use of USB is triggering a hardware or kernel problem in the USB stack which hangs the system.
I have tried the dump1090-mutability, also having the same issue, once everything installed, have to reboot it so that dump1090-mutability will be running, and also not booted. Really strange on this. So I decide to leave as is, installing for RTL-Airband and reboot without any issue.
Well, will still stick to the Raspberry Pi or Orange Pi which is easier to fix the problem.
