How accurate is MLAT?
I’m just thrilled to see all of the new ‘Blue (or is it Purple)’ planes on my PiAware / Dump1090! Certainly I undrstand how ADS-B is very accurate, as the plane is reporting it’s exact location. **What is the accuracy of MLAT, especially since you don’t know precisely where all of the receiving stations antennas are located? ** Thanks again for all of your hard work and it is certainly fun watching your product improve (although my little Pi B+ is now using about 50% of it’s CPU cycles trying to keep up with all of the plans and MLAT…).
I suspect you have tried this, but I would be curious to see how close an MLAT location would be to the actual ADS-B location. Should be possible to ‘ignore’ the location information on ADS-B equiped planes and ‘pretend’ they are only Mode S. Then you could use the MLAT calculations and compare it to the actual location (received from the ADS-B)? Just wondering how close we think MLAT is (in an area with enough receivers). Are we talking 100 meters? More? Less?
If you trust what the plane transmits, anyway :slight_smile:
Receivers with wrong locations get ignored pretty fast - they have large jitter in their clock synchronization. Similarly for receivers with an unstable clock, which is the other common problem (CPU overload / dropping samples manifests as an unstable clock). Somewhere on my list is feeding this information back to the stats pages so you can be aware there’s a problem rather than just wondering why you have no results.
The clock errors for a properly located/synchronized receiver typically add up to maybe 200-300m. The overall error depends on the individual receiver errors and goes down as you get more receivers seeing the target. After filtering I would estimate the usual position accuracy at +/- 500m or better. It depends quite a lot on the positions of the receivers relative to the aircraft. The altitude accuracy is pretty terrible if there’s no transponder altitude available (it’s because most receivers are on the horizon, not below/above(!) the aircraft). The filtering process doesn’t produce results at if it estimates the current error at >4km.
Currently there’s nothing done about things like multipath, because (a) it’s hard without a custom receiver and (b) having lots of receivers is a simpler way to filter that
Comparing back to ADS-B positions was something that I did very early on and the accuracy was good, but it’s a bit of an unfair comparison because you’re using the transmitted position to synchronize the clocks, then using that synchronization info to multilaterate the position … of course they’re going to be close. It was a good way to test the mlat solver if nothing else :slight_smile: It might be interesting to do this for aircraft that transmit a low position accuracy category that aren’t used for sync.
I hate when that happens…
Hahah - I’ve got one from today. Looks like the plane mis-aimed and tried again, mis-aiming again.
http://victorspictures.com/img/s7/v152/p718304115-4.jpg
