Hi!
I’m using feature of reducing writes to the sd-card
sudo bash /usr/share/graphs1090/git/malarky.sh
The issue - last weeks I faced with few power offs (energy company side), and my graphs are sometimes empty. I would like to now - how its possible to change data writes frequency from every 24h to every x hours or smth like that.
Also, does this feature reducing only frequency of data writes, or data size too?
Maybe someone made some measurements when malarky.sh enabled/disabled?
It’s quite a difference … but i don’t remember anymore you’ll have to check yourself.
collectd will write to disk every minute normally, so overall bytes written and write frequency are seriously reduced.
Even changing it to a full write every 2 hours is probably better than disabling it.
Be sure you update before you change the file to make sure it’s also doing the gzip before writing to disk.
Each saving to disk with malarky is less than 10 MB, i’d say with malarky disable you’d get 10 MB an hour easily but again you’d have to test.
It’s about 14-15kB/s with the caching turned off. That’s about 50MB an hour or 1.1GB a day of writes, so significant if you are using a small SD card. If you also are using a cheap SD card, then that could result in quite a shortened expected life.
I was running a Raspberry 3B for > 1 year with graphs1090 installed. And the SD card is still working without a single issue.
A second Pi 4 is still running graphs1090 for 6 months now. In addition it runs WeeWX (a weather software) with lots of writes to the card.
Friend of mine is using meanwhile his third or fourth SD card.
So it really depends on the card itself
I think it’s not only about the amount of data written, but also the frequency.
Might be better to write 1 GB every day instead of 50 MB per hour.
But yeah with the other system i added the IO used is much less, roughly 10 MB a day with the chance of losing a day of data of course when the power fails unexpectedly.
Even though you make it obvious in the install/update script message, I missed the memo on the write reducing on by default update but finally figured it out weeks ago after pondering gaps in my graphs. I settled on 3 minute writes (CM4 eMMC instead of SD card).
Also recently used your guide for moving data history between devices several times. It works perfectly every time.
Issues were when I was changing my station hardware and then troubleshooting. I did shutdown or reboot before powering down sometimes, but not always. That’s when I noticed the writes feature. You’re right though, before that I probably went 6+ months without power disruption.
I’m going to blame this comment for my power going out 90 minutes ago. It’s still out due to wind storm. After 45 minutes downtime, I decided to start ADSB feeding again with backup generator and mobile phone hotspot serving internet to my home router!
My understanding is that dirty_expire works globally, while commit works on a specific mountpoint only (which does not make much difference for most raspberry users).
From ext4 documentation:
Ext4 can be told to sync all its data and metadata
every 'nrsec' seconds. The default value is 5 seconds.
This means that if you lose your power, you will lose
as much as the latest 5 seconds of work (your
filesystem will not be damaged though, thanks to the
journaling). This default value (or any low value)
will hurt performance, but it's good for data-safety.
Setting it to 0 will have the same effect as leaving
it at the default (5 seconds).
This + log2ram makes me pretty confident the sd-card is not stressed much.
Maybe more related to the question how to remove your mountains? Just asking…
I’ve set it up based as suggested by wiedehopf. I do not see a significant change, but that’s not the fault of the graphs1090 script.
This little traffic is hidden behind the larger traffic by the weather station.
