Flight Aware pro stick
Hello just looking for some information about the flight Aware pro stick I recently purchased one secondhand along with a filter just curious if anybody could confirm or deny whether there’s any power coming out the antenna socket (like a bias tee would have ) I see that it’s got a 20 DB integrated amplifier I plan on using a antenna splitter that will not like any voltage coming from the pro stick any information would be appreciated
Thank you
dazzie
As far as I’m aware there’s no power emitting from the antenna socket to the antenna.
The pro stick is powered from the USB side and uses the current to power the internal components but not the cable or the antenna. The amplifier picks up the signals coming in from that side. Amplification starts inside the Pro stick.
Thank you I’ll give it a go report back if it has
Suggest you avoid using a splitter on the incoming antenna signal if you can avoid it. A simple two way splitter will drop your signal level by 3.5db.
