Two quarter wave spider antennas -eight legs- 1090 (69mm) and 768 (77mm) mounted 20’ above ground. Approx 24” apart. Rg6 coax for 978. Superbat from coax for the 1090.
Nooelec Nano three SDRs.
I live <20nm from KDTW. DIRECTLY ON THE APPR/DEP routes for rwy 4/22.
This should all kinds of lit up and I see max 20 airborne aircraft at a time…
Best message rate was around 100-120. Lingers much lower.
Any thoughts?
pi**@749pi:~ $ sudo piaware-status**
PiAware master process (piaware) is running with pid 517.
PiAware ADS-B client (faup1090) is running with pid 663.
PiAware ADS-B UAT client (faup978) is running with pid 13335.
PiAware mlat client (fa-mlat-client) is running with pid 758.
Local ADS-B receiver (dump1090-fa) is running with pid 485.
Local ADS-B UAT receiver (dump978-fa) is running with pid 13258.
dump1090-fa (pid 485) is listening for ES connections on port 30005.
dump978-fa (pid 13258) is listening for UAT connections on port 30978.
faup978 is connected to the ADS-B UAT receiver.
dump978 is producing data on localhost:30978.
Tried -10 to AGC to 30 on gain. -10 seems best.
pi@749pi:~ $ awk “$(cat /run/dump1090*/stats.json| grep total | sed ‘s/.accepted":[([0-9]).strong_signals":([0-9]).*/BEGIN {printf “\nPercentage of strong messages: %.3f \n” , \2 * 100 / \1}/’)”
Percentage of strong messages: 1.560
The about the best I’ve seen.
pi@749pi:~ $ sudo systemctl status dump1090-fa -l
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; vendor pr>
Active: active (running) since Tue 2023-11-21 11:10:06 EST; 2h 34min ago
Main PID: 485 (dump1090-fa)
Tasks: 3 (limit: 2086)
CPU: 57min 18.600s
└─485 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --device-in>
Nov 21 11:10:06 749pi systemd[1]: Started dump1090 ADS-B receiver (FlightAware c>
Nov 21 11:10:07 749pi dump1090-fa[485]: Tue Nov 21 11:10:07 2023 EST dump1090-f>
Nov 21 11:10:07 749pi dump1090-fa[485]: rtlsdr: using device #0: Generic RTL2832>
Nov 21 11:10:07 749pi dump1090-fa[485]: Found Rafael Micro R820T tuner
Nov 21 11:10:08 749pi dump1090-fa[485]: rtlsdr: tuner gain set to about 58.6 dB >
Nov 21 11:10:08 749pi dump1090-fa[485]: adaptive: using 50% duty cycle
Nov 21 11:10:08 749pi dump1090-fa[485]: adaptive: enabled adaptive gain control >
Nov 21 11:10:08 749pi dump1090-fa[485]: adaptive: enabled dynamic range control,>
Nov 21 11:10:08 749pi dump1090-fa[485]: Allocating 4 zero-copy buffers
Nov 21 11:10:18 749pi dump1090-fa[485]: adaptive: reached upper gain limit, halt>
lines 1-20/20
