Must admit, I hate angle and T connectors. From what I understand, RF energy transfers as a energy field along coax. When it meets a 90 degree turn, even if the center conductor is perfectly aligned in the center, the fields do not behave nicely. Inside the angle, is a shorter path than center, and outside the angle, is a longer path. Net result is the input signal is significantly disrupted. Just my experience. Waveguides have similar problems and even coax cables suffer when tight bends are used. Must admit, I love the xx400 cables, large, stiff, minimal bends make them much better carrying UHF signals like our 1090 MHz.
Your description is spot on and provides additional technical detail as to why such āconveniencesā should be avoided. I failed to mention in my first caution that signal levels where also showing losses as compared to the straight coaxial connections. Thanks for your follow up.
Ok, I found out why my heatmap plots look so bad. When you run rtl_power
the bias-t gets turned off. That turns off the LNA and then youāre just looking at noise from the rtl-sdr dongle front end. As far as I can tell, you canāt turn on the internal bias-t in the rtl-sdr dongle and run rtl_power
. You would have to supply an external bias-t voltage to the LNA to turn it on.
Here is a heatmap png where I took out the LNA and just increased the gain in the rtl-sdr dongle to 50 dB. Looks more normal:
You can also tell if the heatmap is going to be reasonable by looking at the lines that heatmap.py puts out when it runs. For the above I got:
loading
x: 4576, y: 60, z: (-34.560000, 4.330000)
drawing
labeling
saving
Here there is a z min to max of about 39 dB. On the previous (noise) plots, z had a min to max of about 3 dB.
Yes, if you have a bias-t-enabled LNA, the cause is most likely that bias-t gets switched off.
Please use rtl_power -T
in gainmap.sh
to switch on bias-t, see rtl-sdr-blog/src/rtl_power.c at master Ā· rtlsdrblog/rtl-sdr-blog Ā· GitHub
So is -T an option in rtl_power
to turn on the bias-t ?
The rtl_power --help
says:
[-T enable bias-T on GPIO PIN 0 (works for rtl-sdr.com v3 dongles)]
But how does that turn on the bias-t in the rtl-sdr dongle?
I guess I would have to wire up GPIO PIN 0 to the LNA to provide power.
To me that looks more like either a mistake or a leftover from very old times; looking at the code, it just sets the right variable for the call itself. ā Besides, Iām using it over here in my (USB-)setup and it works as I expect.
P.S.: Please remember that GPIO for the RTL-SDR /i.e., ,appendix rtl sdr gpio Ā· rfrht/FT991A-PAT Wiki Ā· GitHub) is not to be confused with e.g., a Raspberry Piās GPIO.
Ok, I was assuming that was the Raspberry Piās GPIO.
So I should be able to just use the -T option in rtl_power
to turn on the rtl-sdr bias-t?
Yes, correct, and thatās how I use it.
Youāre right the -T option in rtl_power
does turn on the bias-t.
Thanks.
By the way it looks like this same problem with the bias-t came up in July 2019 on this thread (Message 353):
Same setup that I have for 1090. His heatmap plot looked identical to what I had when the bias-t was off.
