Yep. I did that and the T620 is worse than all my Pi’s. I’m pretty sure it’s because my Pi’s run RadarBox SDRs that are filtered and amplified.
I went with the Nano 3 SDRs because they are small and I can fit them inside on the 620’s two internal USB ports. I drilled a hole on the front and mount the antenna mast there. That way there isn’t a bunch of junk sticking out of the 620 like Frankenstein’s Monster.
It would seem that the Nano 3’s are the weak link. That’s why I was thinking that an amp would be helpful. But would I want to filter and amplify? Depending on the size of the LNA and filter I may still be able to keep everything inside the 620’s case too.
zs6bv
October 18, 2022, 9:21am
962
When you amplify you also amplify the noise, so amplify and filter together rather.
I understand an amplifier will amplify noise. But, wouldn’t the tuned SDRs only receive 978 and 1090 anyway?
Except that any signal at 1090 MHz for example will still have noise on it. Think of it that way.
The nano sdrs aren’t as good for ADS-B and yes you’re also missing an LNA / filter in front.
There is a pretty good combine filter / LNA by uputronics or from rtl-sdr, consider either of those.
And consider just not using a nano if you want best performance i think.
The noise isn’t the issue, interference is from strong emitters is.
The LNA / SDR can get overloaded from other frequencies causing noise on the frequency you want to receive.
Does anyone have any experience with this filter? I like it because it may be small enough where I can keep it inside the T620.
Well, if no one has any experience with the Stratux filter…
Which filter do people like?
Hello,
This wont work for me with Bullseye OS, cannot install python. Can anyone help please?
sudo apt update
sudo apt install rtl-sdr
sudo apt install python3
sudo apt install python3-pil
sudo wget https://raw.githubusercontent.com/keenerd/rtl-sdr-misc/master/heatmap/heatmap.py
sudo chmod +x heatmap.py
sudo systemctl stop dump1090-fa piaware
sudo rtl_power -f 800M:1200M:100k -i 30 -c 50% -e 30m -g 30 -F 9 >scan.csv
Wait till scan finishes (15 to 30 minutes)
sudo reboot
sudo ./heatmap.py scan.csv scan.png
Thank you, i just did this and giving me ‘No supported devices found’. I’m using the airspy mini
test@raspberrypi:~ $ sudo rtl_power -f 800M:1200M:100k -i 30 -c 50% -e 30m -g 30 -F 9 >scan.csv
Number of frequency hops: 286_power -f 800M:1200M:100k -i 30 -c 50% -e 30m -g 30 -F 9 >scan.csv
Dongle bandwidth: 2797202Hz
Downsampling by: 1x
Cropping by: 50.00%
Total FFT bins: 9152
Logged FFT bins: 4576
FFT bin size: 87412.56Hz
Buffer size: 16384 bytes (2.93ms)
Reporting every 30 seconds
No supported devices found.
This wont work on AirSpy .
It worka on RTL based dongles such as DVB-T, Flightaware Prostick and Flightaware Prostick Plus, etc.
Taxom:
Yes!
How good/bad this filtered LNA is?
What is SQ61D chip?
No datasheet
Took a while, but the best I’ve come up with is a 4.8V low noise LDO.
A Ricoh RP130K481A
Any guesses for the amp?
Edit:
No it’s not.
It looked good, but the “SQ” isn’t the SOT23-5 package
3M9009 is TQP 3 M 9009 amp
Taxom
June 8, 2023, 11:28pm
979
I use it now, it seems to work fine.
Statistics for sites feeding ADS-B flight tracking data to FlightAware. Sites, users, countries, regions, and teams are ranked by the number of aircraft reported.
Hi! I do the test.
RTL SDR + Antenna “5 dBi” (
https://es.aliexpress.com/item/1005003628094587.html?spm=a2g0o.order_list.order_list_main.83.cb54194ddX2nSj&gatewayAdapt=glo2esp ).
I was thinking of buying a filter but in my country filters are difficult to obtain and import from other countries. Is it worth buying an uputronics?
I use 29.7 db Gain
Having a filter is preferable, but if filter is very costly, you may servive even without it.
Also try following scan which shows intensity of interfering RF noise also:
