Well I just produced my first scan thanks to the clear instruction from abcd567 in post 2 so thanks very much for that!
A cursory glance sees massive activity from at least 800MHz â 822MHz (based in the UK and wondering if that might be Mobile and/or DTV?) and also from 925MHz â 961MHz (Mobile?) but the 1090MHz signal looks weak by comparison.
Iâm guessing this looks to be a good candidate for the dark blue FA 1090 Filter or would I be better served by a cavity/3-pole filter or similar?
Iâm going to give the system a day or two to settle because it was only after I rebooted I realised I had previously edited the dump1090-fa to enable Adaptive Dynamic Range so not exactly a like-for-like comparison.
Prior to the edit sudo systemctl status dump1090-fa reported;
â dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
Active: active (running) since Sat 2022-01-29 08:17:07 GMT; 1 weeks 5 days ago
Main PID: 570 (dump1090-fa)
Tasks: 3 (limit: 4915)
ââ570 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --gain 60 --fix --lat xx.xxxxx --lon x.xxxxx --max-range 360 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005 --json-location-accuracy 1 --lat xx.xxxxxx --lon xx.xxxxxx --write-json /run/dump1090-fa
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
And following the first reboot since the edit it now looks like this;
Active: active (running) since Mon 2022-02-14 00:35:20 GMT; 25min ago
Main PID: 535 (dump1090-fa)
ââ535 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --gain 60 --adaptive-range --fix --lat xx.xxxxx --lon xx.xxxxx --max-range 360 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005 --json-location-accuracy 1 --lat xx.xxxxxx --lon xx.xxxxxx --write-json /run/dump1090-fa
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: Found Rafael Micro R820T tuner
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: rtlsdr: tuner gain set to about 58.6 dB (gain step 29) (tuner AGC enabled)
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: adaptive: using 50% duty cycle
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: adaptive: enabled adaptive gain control with gain limits 0.0dB (step 0) .. 58.6dB (step 29)
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: adaptive: enabled dynamic range control, target dynamic range 30.0dB
Feb 14 00:35:22 RaspberryPi-air dump1090-fa[535]: Allocating 4 zero-copy buffers
Feb 14 00:35:32 RaspberryPi-air dump1090-fa[535]: adaptive: available dynamic range (29.1dB) < required dynamic range (30.0dB), switching to downward scan
Feb 14 00:35:32 RaspberryPi-air dump1090-fa[535]: adaptive: changing gain from 58.6dB (step 29) to 49.6dB (step 28) because: probing dynamic range gain lower
Feb 14 00:35:32 RaspberryPi-air dump1090-fa[535]: rtlsdr: tuner gain set to 49.6 dB (gain step 28)
Feb 14 00:35:42 RaspberryPi-air dump1090-fa[535]: adaptive: available dynamic range (38.6dB) >= required dynamic range (30.0dB), stopping downwards scan here
So it looks to me like Adaptive Dynamic Range has reduced the Gain one step from 60 â 49.6 in the 30 minutes or so following the reboot which might go some way towards the 1090MHz signal looking a little weak? Or maybe because the graph was generated just after midnight with only 15 aircraft being received rather than the usual 200+?
Anyway it looks to me like itâs time to put the 1090 filter inline and run the heatmap waterfall graph again to see if that will reduce the out of band signals and check what effect that might have had on the 1090MHz signal read in conjunction with wiedehopfâs Graphs package.
This stuff is greatâŚthanks guys!
Just want to make sure Iâm treading the right path hereâŚ
Thanks & kind regards,
-=Glyn=-
