IIRC this is mostly that you’re seeing the edges of one of the filters (I suspect the downsampling filter in the 2832). i.e. rtl_power is using, say, 2MHz wide bins, but the filter is a bit less than 2MHz wide so you see attenuation of the background noise at the edges of the bins. I think rtl_power maybe has some sort of option to overlap the bins and only take the FFT results from the central region when pasting them together, but it’s been a long time since I looked at it.
edit: ok, that’s -c, but there’s also some strange logic that ignores it in some cases…
That makes more sense and explains the presence at higher gains. I only see them at very low gains on the FA Pro Stick Plus; at higher gains they are scaled down into oblivion for the most part.
I thought so also (my question was a bit loaded). I had bought the FA 978-1090 MHz ADS-B Bandpass SMA Filter. But it didn’t help.
From the images above, most all of the bad stuff from 800-900 MHz disappeared. But little from 900-950 MHz. So I started looking for info about the FA 978-1090 MHz ADS-B Bandpass SMA Filter. I found some scans on Amazon including these two images below.
For the time being, here are the scan results using different combinations of filters & dongles using Noise Source. The last one is for Triple Filtered LNA
I tested the FA filter with a spectrum analyzer and the scans posted on Amazon are close to what I found.
To reject 965 and pass 978 calls for a selective SAW or cavity filter. I’m using a 4 element cavity filter with good success on 978 on my very noisy urban location.
In the USA the 902-928 band is full of Part 15 devices and in urban areas is quite noisy. “Smart meters” have been using the band too. There are SMR repeater and trunking systems in the 900 MHz band, too.
Thanks for the reminder about Part 15 devices! I have an electrical smart meter in my backyard though I have not found the exact frequency (still searching). I see LoRa is near 915 MHz.
Too much noise for a wide open front end receiver!
Did you purchase or build the 4 element cavity filter for 978 MHz? If purchase, where was it purchased from?
It was very kind of Oliver (@obj) to update it today, as I cannot edit my old posts in Flightaware forum.
As in other forums there is no restriction on updating old posts, today I have updated “Do I Need A Filter” in both the Flightradar24 and Planefinder forums.
Uputronics makes one, here’s the page with the datasheet. I and a few others have their 1090Mhz filtered preamp which is good; I expect the UAT version will be equally good.
I did look at the Uputronics 978MHz UAT Filtered Preamp but the data sheet doesn’t have any technical info about the filter (e.g., what frequencies it rejects and what is accepted, and how much attenuation at those frequencies). I’ll write them a note. Hopefully they will write back. Thank you!
I’ve always had good responses from Anthony there. If you get details or a link to more tech data would you mind posting the info back to this thread please, it’ll be handy for others in the future? Thanks.
I mean, there is literally no other product for 978 MHz available as far as i know.
Well i suppose the new 978 MHz dongle by AirNav will have a SAW filter builtin as well.
But for that you probably won’t get any data.
Just curious which specs you are looking for.
To stop out of band intermodulation an 978MHz SAW bandpass filter, which has a 15MHz bandwidth is also present. The insertion loss of this filter is approximately 2.3dB, which does increase the overall noise figure of the unit to 0.75dB.
Anyhow if you need more specifications, writing them is the right approach
I am looking for something similar to this. If 966 MHz & 990 MHz were 25 dB down instead of 35 dB down that would be great! None of the below is written in stone.
I copied that text from the product text from the uputronics 978 MHz amp.
It’s a bit hidden in all that text, but it’s there
Bandwidth is usually specified using the -3 dB points, isn’t it?
They should offer an option with a 2nd SAW filter on the input, that would be nice!
A tiny bit less sensitivity but much better suited to high RF environments!
