Debian Bookworm kills piaware.service minutes after starting
Hi Eric
any update to the new bookworm repository?
Reading package lists... Done
E: The repository 'http://flightaware.com/adsb/piaware/files/packages bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
Ign:6 http://www.flightaware.com/adsb/piaware/files/packages bookworm InRelease
Err:7 http://www.flightaware.com/adsb/piaware/files/packages bookworm Release
  404  Not Found [IP: 2606:4700:4400::6812:27c9 80]
pi@flightrecorder:/etc/apt/sources.list.d$ cat flightaware-apt-repository.list
# This file is automatically generated by the flightaware-apt-repository package
# to point to the correct FlightAware repository for the currently installed Debian OS.
deb http://flightaware.com/adsb/piaware/files/packages bookworm piaware
There is connectivity
pi@flightrecorder:/etc/apt/sources.list.d$ telnet 2606:4700:4400::6812:27c9 80
Trying 2606:4700:4400::6812:27c9...
Connected to 2606:4700:4400::6812:27c9.
Escape character is '^]'.
There doesn’t seems to be a release file?
We have not released bookworm packages for piaware yet.
probably will happen this week, but not guaranteed.
Thanks! Few other flight tracking sites are neither ready yet so I moved back to the old SDcard.
Will there be 64bit support in the future?
Yes, planning to release armhf + arm64 packages for bullseye and bookworm.
(1) First step is is to wait till the Raspberry Pi OS Bookworm gets fixed.
It has a USB bug, which causes dump1090-fa and rtl_test to fail to detect / use the dongle.
(2) After fixing the USB bug, I could install dump1090-fa and piaware, as well as Flightradar24, Planefinder, and Radarbox24 feeders because the Raspberry Pi OS is multi architecture (arm64/aarch64 AND armhf)
Click on Screenshot to See Larger Size
@abcd567 your such a value for this community, many thanks for sharing your knowledge. I’ll fire up the pi 3b+ (where ill move the SD card tot the pi4 after install) and start testing with the commands you shared.
What I did was moving my bullseye 32bits install to a bookworm 64bits install. I’m using an airspy and 2 RTL-SDR dongles for VHF. Indeed the airspy worked fine but the rlt_test had major issues with communicating to the RTL-SDR dongle. And as I dont want to get gaps on my graphs1090 I did not run it for hours. At least my local TAR1090 showed airplanes via the airspy.
Is there any bypass for the USB problems? We might need to wait for the USB issue is solved, is there any tracking available? Are you able to ping this thread when its released? :innocent:
Due to the USB load of the Airspy combined with 2 RTL-SDR’s i need to increase the usbfs_memory
pi@flightrecorder:~ $ cat usb_buffer.sh
#!/bin/sh
PCM_ID="/sys/module/usbcore/parameters/usbfs_memory_mb"
BUFSIZE="0"
# Adjust usbfs memory
if [ -f $PCM_ID ]; then
        echo $BUFSIZE > $PCM_ID
fi
If I do understand well, I need to add the foreign architectures to get the packages installed well. What is your vision about some excotic sites which does not really have an active package development. I’m thinking about removing them when I move to the new install:
Opensky: last update 2018
adsbhub bash script
radarvirtuel.com executable
Well booted up and tested some things, found some other post of you.
Let me handle them step by step looking for tips and providing you a fresh view on new installs today.
apt-cache policy piaware | grep Installed
apt-cache policy fr24feed | grep Installed
Installed: 1.0.41-0
apt-cache policy mlat-client | grep Installed
apt-cache policy rbfeeder | grep Installed
apt-cache policy pfclient | grep Installed
Installed: 5.0.161
MLAT-CLIENT
pi@flightrecorder:~ $ sudo apt install mlat-client
Building dependency tree... Done
E: Unable to locate package mlat-client
There seems no mlat-client for bookworm availably your site doesn’t show an bookworm version?
RBFEEDER
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.SI2MYNfRd5/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 1D043681
gpg: key D4F914061D043681: "AirNav Systems <jceara@airnavsystems.com>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
Don't know how to install for a distribution named
case "$VERS" in
    stretch)
        echo 'deb https://apt.rb24.com/ stretch main' > /etc/apt/sources.list.d/rb24.list
     buster)
        echo 'deb https://apt.rb24.com/ buster main' > /etc/apt/sources.list.d/rb24.list
     bullseye)
        echo 'deb https://apt.rb24.com/ bullseye main' > /etc/apt/sources.list.d/rb24.list
        echo "Don't know how to install for a distribution named $DIST" >&2
        exit 1
esac
As it seems the script logic could not handle the bookworm output gathered, should I change the script to match bookworm and install bullseye?
     bookworm)
And yes that change worked fine:
pi@flightrecorder:~ $ apt-cache policy rbfeeder | grep Installed
  Installed: 1:1.0.8+deb11.1
PIWARE
As stated earlier in this topic, package will be released soon
  Installed: 1.0.41-0
  Installed: 5.0.161
@butterfly2
Please see following thread for hack to fix USB bug in current release of RaspberryPi OS Bookworm (10-10-2023)
Raspberry Pi OS Bookworm released
wget http://apt.rb24.com/inst_rbfeeder.sh
sudo nano inst_rbfeeder.sh
Scroll down till you see line which starts with VERS=lsb_release
Just below this line, add VERS=bullseye
CAUTION: Do NOT leave any blank space on either side of = sign.
Save file, and issue following command
sudo bash inst_rbfeeder.sh
The above command will start and complete installation of Radarbox24 feeder on Bookworm :slightly_smiling_face:
For RadarBox24 feeder, build mlat-client from source code, dev branch ver 0.2.13, which is compatible to Bookworm
sudo apt update
sudo apt install -y git curl build-essential debhelper
sudo apt install -y python3 python3-dev dh-python
git clone https://github.com/mutability/mlat-client
cd mlat-client
git fetch --all
git reset --hard origin/dev
sudo dpkg-buildpackage -b -uc
## After mlat client  package is built
cd .. /
sudo dpkg -i mlat-client_*.deb
Run following script on Bookworm. It will install piaware ver 9.0~dev on Bookworm. :slightly_smiling_face:
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-piaware.sh)"
Thanks in the end it failed, just to let you know how your script runs.
Successfully installed MlatClient-0.2.13
make -C dump978 faup978 VERSION=9.0~dev
make[2]: Entering directory '/home/pi/piaware_builder/package-bookworm/dump978'
g++ -g -O2 -ffile-prefix-map=/home/pi/piaware_builder/package-bookworm=. -fstack-protector-strong -Wformat -Werror=format-security -std=c++11 -Wall -Wno-psabi -Werror -O2 -g -Ilibs -Wdate-time -D_FORTIFY_SOURCE=2 -DVERSION=\"9.0~dev\"  -c -o faup978_main.o faup978_main.cc
g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [<builtin>: faup978_main.o] Error 1
make[2]: Leaving directory '/home/pi/piaware_builder/package-bookworm/dump978'
make[1]: *** [debian/rules:73: build_dump978] Error 2
make[1]: Leaving directory '/home/pi/piaware_builder/package-bookworm'
make: *** [debian/rules:116: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
[ERROR] Error in line 121 when executing: dpkg-buildpackage -b --no-sign
[ERROR] Error in line 26 when executing: sudo bash -c "$(wget -O - https://github.com/abcd567a/temp/raw/main/install-piaware-debian-12.sh)"
@obj
Yesterday I have successfully built piaware ver 9.0~dev using Flightaware source-code, and it was OK.
After seeing @butterfly2’s post, I just now tried to build it again, and it failed exactly like it failed with @butterfly2 .
Checked source-code at Flightaware Repository.
Found some changes have been made in the dev branch of Github/Flightaware/Piaware_builder about 3 hrs ago, which seem to cause this failure.
Showing 1 changed file with 1 addition and 1 deletion.
2 changes: 1 addition & 1 deletion 2 sensible-build.sh
@@ -86,7 +86,7 @@ shallow_clone https://github.com/flightaware/tcllauncher.git v1.10 $OUTDIR/tclla
shallow_clone https://github.com/flightaware/dump1090.git dev $OUTDIR/dump1090
shallow_clone https://github.com/mutability/mlat-client.git dev $OUTDIR/mlat-client
shallow_clone https://github.com/mutability/mlat-client.git v0.2.13 $OUTDIR/mlat-client
shallow_clone https://github.com/flightaware/dump978.git dev $OUTDIR/dump978
You ran out of memory. Build on a machine with more memory, or add swap.
@butterfly2
Please see following post for method to add swap.
If the total memory (RAM + builtin swapfile (if any) + your added swap file) is 2.5 GB or larger, then piaware, dump1090-fa and dump978-fa pckages will built without any memory issue.
After building and installing the packages (piaware, dump1090-fa, dump978-fa), you can delete the swap file you have added to free up space on microSD card.
@obj
Up till October 21, 2023, I have several times built piaware ver 9.0~dev successfully on RPi OS Bookworm and Armbian OS Bookworm.
Today I tried again to build piaware 9.0~dev on RPi Model 4 with 4GB RAM, and it failed with following error:
make[1]: *** [debian/rules:92: install_mlat-client] Error 1
make: *** [debian/rules:116: binary] Error 2
dpkg-buildpackage: error: debian/rules binary subprocess returned exit status 2
Click on Screenshot to see larger Size
Well, OK, but you said you had the same error. That’s not the same error, and you haven’t given enough context to diagnose the problem.
Our CI environment builds the current dev branch OK on both bookworm armhf and bookworm arm64.
edit: if you still have problems building please create a github issue with full logs.
Thanks @obj and @abcd567 as shared im building on a 3B+ because i don’t want the graph1090 stats to get filled with gaps. The Pi 4 has 8G and the 3b+ 1G if I recall well.
Will try to add swap and also noticed that there was some high CPU process running which consumes resources.
Thanks for the help!
Finally found the problem! My install had some sort of corruption.
Last night, after seeing your post, I tried several times, but always build process aborted with same error message. Got fed up and went to sleep.
Today morning re-imaged RPi4 4GB ram, with 64-bit Raspberry Pi OS Lite Bookworm (2023-10-10).
Then to solve USB / Dongle detection issue, upgraded kernel to 6.1.58-v8+ by command sudo rpi-update.
After this ran the install scripts from my Github page, and all went well and could built & install:
  • piaware 9.0~dev
  • dump1090-fa 9.0~dev
  • dump978-fa 9.0~dev
  • piaware-web
    :smiley:
https://www.flightaware.com/adsb/stats/user/abcd567#stats-76000
Works for me on a Pi 5 without updating the firmware.
Last night I ended up in same error, but this time I could find what exactly caused above failure. It was failure of package building process to install following package:
./wheels/MlatClient-0.2.13-cp311-cp311-linux_aarch64.whl
The reason for failure was that I have built and installed mlat-client_0.2.13_arm64.deb for Radarbox24 feeder., and piaware build process detected it and failed to install its own mlat-client
The message given by dpkg-buildpackage -b command ` is given below:
/home/pi/piaware_builder/package-bookworm/debian/venv/bin/python -m pip install --no-index --no-deps --require-virtualenv /home/pi/piaware_builder/package-bookworm/wheels/MlatClient-*.whl
Processing ./wheels/MlatClient-0.2.13-cp311-cp311-linux_aarch64.whl
MlatClient is already installed with the same version as the provided wheel. Use --force-reinstall to force an installation of the wheel.
I solved this problem by following method:
sudo dpkg --purge mlat-client
cd /home/pi/piaware_builder/package-bookworm
After uninstalling stand-alone mlat-client_0.2.13, the piaware package was built successfully. :slightly_smiling_face:
After building piaware package, I reinstalled stand alone mlat-client for Radarbox24 feeder
sudo dpkg -i mlat-client_0.2.13_arm64.deb
I have also noted that mlat-clients installed under virtual enviroments by adsbexchange and adsbfi do not cause this issue. It is only the stand-alone /usr/bin/mlat-client which caused this failure.
