Hello guys!
I am running into problems with my Piaware now ![]()
It has run without a hitch for 88 days, now it will not stay up for more than a couple of hours. It will start with losing the data feed, then most of the time the checks in will follow.
I am using a 2.5 amp power supply with a powered USB bus to run the dongle (which is attached via a 15th USB lead), the temps stay under 30* and the processor is under 10% with 50% of the sd card free. It is hardwired in the network.
piaware.out below
I am at a loss.
04/16/2016 11:17:18 ****************************************************
04/16/2016 11:17:18 piaware version 2.1-5 is running, process ID 512
04/16/2016 11:17:19 your system info is: Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
04/16/2016 11:17:19 Connecting to FlightAware adept server at piaware.flightaware.com/1200
04/16/2016 11:17:19 ADS-B data program ‘dump1090’ is listening on port 30005, so far so good
04/16/2016 11:17:19 Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 30.471 --lon -90.043
04/16/2016 11:17:19 Started faup1090 (pid 825) to connect to dump1090
04/16/2016 11:17:19 Connection with adept server at piaware.flightaware.com/1200 established
04/16/2016 11:17:19 FlightAware server SSL certificate validated
04/16/2016 11:17:19 encrypted session established with FlightAware
04/16/2016 11:17:19 autoUpdate in adept config is enabled, allowing update
04/16/2016 11:17:19 manualUpdate in adept config is enabled, allowing update
04/16/2016 11:17:19 multilateration support enabled (use piaware-config to disable)
04/16/2016 11:17:20 logged in to FlightAware as user Louisianapilot
04/16/2016 11:17:20 multilateration support enabled (use piaware-config to disable)
04/16/2016 11:17:20 multilateration data requested, enabling mlat client
04/16/2016 11:17:20 Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30104 --udp-transport 70.42.6.198:6458:2966002973
04/16/2016 11:17:24 piaware received a message from dump1090!
04/16/2016 11:41:24 1 msgs recv’d from dump1090; 1 msgs sent to FlightAware
04/16/2016 11:41:25 timed out waiting for alive message from FlightAware, reconnecting…
04/16/2016 11:41:25 TLS alert: close notify
04/16/2016 11:41:25 multilateration data no longer required, disabling mlat client
04/16/2016 11:41:25 reconnecting in 115 seconds…
04/16/2016 11:41:26 mlat(855): fa-mlat-client 0.2.4 starting up
04/16/2016 11:41:26 mlat(855): Using UDP transport to 70.42.6.198:6458
04/16/2016 11:41:27 mlat(855): Input connected to localhost:30005
04/16/2016 11:41:27 mlat(855): Disconnecting from localhost:30005: Client shutting down
04/16/2016 11:41:27 mlat(855): Exiting on connection loss
04/16/2016 11:41:55 3 msgs recv’d from dump1090 (2 in last 1m); 1 msgs sent to FlightAware
04/16/2016 11:43:20 Connecting to FlightAware adept server at piaware.flightaware.com/1200
04/16/2016 11:43:20 Connection with adept server at piaware.flightaware.com/1200 established
04/16/2016 11:43:20 FlightAware server SSL certificate validated
04/16/2016 11:43:20 encrypted session established with FlightAware
04/16/2016 11:43:20 autoUpdate in adept config is enabled, allowing update
04/16/2016 11:43:20 manualUpdate in adept config is enabled, allowing update
04/16/2016 11:43:20 multilateration support enabled (use piaware-config to disable)
04/16/2016 11:43:20 logged in to FlightAware as user Louisianapilot
04/16/2016 11:43:21 multilateration support enabled (use piaware-config to disable)
04/16/2016 11:43:21 multilateration data requested, enabling mlat client
04/16/2016 11:43:21 Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30104 --udp-transport 70.42.6.191:6777:583568058
04/16/2016 11:43:22 mlat(1411): fa-mlat-client 0.2.4 starting up
04/16/2016 11:43:22 mlat(1411): Using UDP transport to 70.42.6.191:6777
04/16/2016 11:43:22 mlat(1411): Input connected to localhost:30005
04/16/2016 11:43:22 mlat(1411): Beast-format results connection with localhost:30104: connection established
04/16/2016 11:45:52 mlat(1411): Disconnecting from localhost:30005: No data (not even keepalives) received for 150 seconds
04/16/2016 11:45:52 mlat(1411): Input connected to localhost:30005
04/16/2016 11:46:55 7 msgs recv’d from dump1090 (4 in last 5m); 1 msgs sent to FlightAware
04/16/2016 11:48:22 mlat(1411): Disconnecting from localhost:30005: No data (not even keepalives) received for 150 seconds
04/16/2016 11:48:22 mlat(1411): Input connected to localhost:30005
04/16/2016 11:50:53 mlat(1411): Disconnecting from localhost:30005: No data (not even keepalives) received for 150 seconds
04/16/2016 11:50:53 mlat(1411): Input connected to localhost:30005
04/16/2016 11:51:55 7 msgs recv’d from dump1090 (0 in last 5m); 1 msgs sent to FlightAware
