I’ve been on FA for awhile, but just recently got back into sharing data and upgrading my old RTL dongle with the stubby antenna.
I picked up several Raspberry Pi Zero W’s (amazing deal for what they can do) and switched the setup out to the FA Pro stick with filter built in and FA antenna on Amazon with 15 feet of RG58 N to SMA cable.
I have alongside it another RPi0 with another FA Pro stick with filter built in with this ebay antenna on 15 feet of RG316 MCX cable running through two 50 ohm. SMA to MCX converters.
They are mounted right next to each other on my roof and I’m seeing the cheapo eBay antenna outperform the 4x more expensive FA antenna, even with the better RG58 cable. I just changed it out so I will continue to monitor I suppose before possibly sending the FA antenna back I thinks.
Just for ‘fun’, loosen the N plug on the antenna side to see if it makes any difference. Also, just to be sure, check that the male SMA plug is not of the RP-SMA type.
if this cheapo antenna is out performing Flightaware 26" antenna, then there is something wrong with your FA Antenna installation: connectors most likely, as @Dxista has already pointed out.
Just for ‘fun’, Do loosen the N plug on the antenna side to see if it makes any difference.
Backed the N plug off a bit. Still seeing about 10% more messages on the ebay antenna setup, but similar hourly planes numbers. PiAware Skyviews are pretty much identical except a couple planes are different. I can try getting a N to MCX adapter to really rule out the RG58 cable I suppose, but very interesting so far.
The default is automatic gain control?
Anyway if you want to get the maximum out of your gear you will need to adjust the gain.
Try a gain of 30 as a start.
If you have no signals in skyview which are greater than -10 then you can start back up but my guess would be that 30 is about the correct gain for that antenna and stick.
There are more detailed explanations of how to set gain but this should be a good baseline.
Also with strong interference from other signals you might need filters before you can fully use the gain of the FA antenna.
YES, with a high gain antenna like FA 26" antenna, ProStick Plus (with built-in filter) may need an external filter also at locations with strong Cell / Mobile signals.
