Just want to confirm there is no piaware (or Debian) problem needing a fix for keep my piaware static ip from repeatedly being bounced. It seems to me to be a wifi issue because I can restart the gateway and recover real-time skyview data. Any comments?
I don’t know of any problems with static IPs, but your post is very short on information. What do you mean by “bounced”? What sdcard image are you using? How have you configured it?
Thanks for your reply. I keep losing dynamic skyview for no apparent reason. Rebooting the router restores skyview buy it will drop again. I am using 3.7.2 and the piaware-config text file is:
I’m not sure why piaware is even asking for the broadcast address as it can be calculated from the address and the netmask.
Try this: wireless-broadcast 192.168.0.255
I’m not 100% positive on this, but i’m pretty sure.
See this here: IP Subnet Calculator
Note that the subnet is the same as the netmask, which can be written in long and /xx notation.
You also want to stay out of the DHCP address range of the router.
So in the router you can usually configure which addresses it will give via DHCP.
Don’t use any of those addresses or it could lead to problems.
Maybe just try 222 instead of 22 as the IP address if changing the broadcast address doesn’t help.
How is your router configured? If it is using DHCP, a fix is to make reservations (by mac address) for the device ip addresses because the router may be assigning a different ip for the mac address.
