hi , my try to get flight information api , l used example gave in FlightXML2 using jquery . when l run code there is no data to show . and when l checked console in google chrom l found data coming from url json is blocked
my code
<html>
<head>
</head>
<body>
<form onsubmit="return false;">
<p>Enter a flight ident to track:
<input type="text" name="ident" id="ident_text" value="UAL423" />
<input type="submit" id="go_button" value="Go" />
</p>
</form>
<div id="results"></div>
<div id="map_div" style="width: 400px; height: 300px"></div>
</body>
<script type="text/javascript" src="http://www.google.com/jsapi"></script>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js"></script>
<script type="text/javascript">
var fxml_url = 'https://xxx:xxxxxx@flightxml.flightaware.com/json/FlightXML2/';
google.load("visualization", "1", {packages:["map"]});
// When the button is clicked, fetch the details about the entered flight ident.
$(document).ready(function() {
$('#go_button').click(function() {
$.ajax({
type: 'get',
url: fxml_url + 'FlightInfoEx',
data: { 'ident': $('#ident_text').val(), 'howMany': 10, 'offset': 0 },
success : function(result) {
if (result.error) {
alert('Failed to fetch flight: ' + result.error);
return;
for (flight of result.FlightInfoExResult.flights) {
if (flight.actualdeparturetime > 0) {
// display some textual details about the flight.
$('#results').html('Flight ' + flight.ident + ' from ' + flight.origin + ' to ' + flight.destination);
// display the route on a map.
fetchAndRenderRoute(flight.faFlightID);
return;
alert('Did not find any useful flights');
error: function(data, text) { alert('Failed to fetch flight: ' + data); },
dataType: 'jsonp',
jsonp: 'jsonp_callback',
xhrFields: { withCredentials: true }
// Fetch the planned route for a specified flight_id.
function fetchAndRenderRoute(flight_id) {
$.ajax({
type: 'GET',
url: fxml_url + 'DecodeFlightRoute',
data: { 'faFlightID': flight_id },
if (result.error) {
alert('Failed to decode route: ' + result.error);
return;
// Initialize a data table using the Google API.
var table = new google.visualization.DataTable();
table.addColumn('number', 'Lat');
table.addColumn('number', 'Lon');
table.addColumn('string', 'Name');
// Insert all of the points into the data table.
var points = result.DecodeFlightRouteResult.data;
table.addRows(points.length);
for (rowid = 0; rowid < points.length; rowid++) {
table.setCell(rowid, 0, points[rowid].latitude);
table.setCell(rowid, 1, points[rowid].longitude);
table.setCell(rowid, 2, points[rowid].name + ' (' + points[rowid].type + ')' );
// Render the data table into a map using Google Maps API.
var map = new google.visualization.Map(document.getElementById('map_div'));
map.draw(table, {showTip: true, showLine: true, lineWidth: 3, lineColor: '#009900'});
error: function(data, text) { alert('Failed to decode route: ' + data); },
dataType: 'jsonp',
</script>
</html>
