NO disc with Spider, only vertical and radials.
I took the disc off, and made the top bars between the down legs 30mm, which is the base of the original antenna.
100.7nm at 29,000 feet. Another at 88NM.
Iām using 17ga galvanized wire, because I happened to have a roll.
Should I use some 12 or 14 ga copper instead?
Lots more flights visible, but thatās just evening traffic, in general.
Comparison to Live Flight Tracker - FlightAware on another monitor is helpful
This is ok.
Not necessary.
Can you please take a close-up photo of spider and post it?
Iām currently visiting a friend in California but even in the UK am not particularly interested in aircraft long distances away. In UK I am close to Heathrow so see much interesting traffic at around 8000 feet.
May experiment with different antenna length upon return to UK.
Geffers
I really think that the suggestion with the wire rolled around the base pin is not great. It creates an inductance at that point - remember the high frequency signals are traveling only on the outside portion (skin) of the wire.
I had the same antenna and I have cut the wire with a pair of pliers at 65mm (there is a portion of un-shielded wire in the base too). And then used the lid of a mushroom can as ground.
For the situation of the OP, those walls can be shielding the signal, and the only ones that he can āseeā are the ones that are bouncing trough the skylight, on the side walls. So antenna doesnāt have as much importance as luck (plane to be in the right place geometrically).
65-67mm on this antenna is right in the middle of the coil. (picture of the original with a ruler, above).
I could solder a copper wire directly to the threaded stub (or to a nut), since this seems to be the best antenna.
Looking at the HeyWhatāsThat map, my current pattern looks like the one that I can expect.
Today is 21,230 <50, 2,889 50-100, 288 100-150 NM. The 50-100 is 13%. It was 17% earlier today. With the original antenna, it was around 7%, but that number varies with air traffic, which is quite variable. My sky is not full of airplanes. The area around SFO is in the shadow of some mountains for me. I have seen 20 at a time. I have seen none, or two. Comparing to Flightaware/Live shows that Iām not missing much in the coverage pattern that is becoming familiar. Iāve started watching the Age column in SkyView, to know what the maximum range is of a flight before it disappears.
This antenna is supposed to be optimized for ADS-B. Itās 170cm with a coil at 50cm for 10 loops. Is it a 3/4 wave antenna? What if I mimicked that length and coil for my spider legs? What if i used a straight 3/4 length 201mm for my legs? 201 mm legs and aerial, straight, soldered to the stub?
Length of whip is not critical. I have tried whips in lengths 52mm, 67mm, and 72mm. There is some noticeable difference, but less than 10%.
Not necessary. Few turns of wire over the threaded stud are ok. The turns are for mechanical reason to hold the wire in place. Electrically, the turns do not form a coil, as almost entire RF current directly passes through the first point of contact between wire and stud, and does not follow the coil route.
Clarence, when you refer to polar plots is that on the Flight Aware stats or FlightRadar24 page?
I have the same R-Pi feeding both FA and FR24 and whilst direction is similar range seems to vary if I view each individual stats page.
Geffers
I am referring to the piAware ADS-B stats page.
This spider is working well.
The 50-100 message count is 20% of the <50 number. Thatās three times what my lowest antenna setup had.
My spider legs are not electrically connected to the ground of the antenna/cable.
I presume that is okay, since the magnetic ground plane antenna would normally be sitting, I suppose, on a car roof with no electrical connection.
The braid of coax is solidly connected to the 1 inch dia magnetic base. Through the capacitance formed between antenna base and the ground plane, the groundplane gets connected to braid of coax, even though there is no direct connection.
This pic also shows the effective start of the antenna
(where the center conductor ceases to be shielded)
This is the point where measurements need to start when determining where to make a cut to produce a 1/4 wave etc.
I must say, I started this adventure with FlightRadar24.
I saw a track that someone had posted of a CalFire spotter plane, which is, unfortunately, of interest in Northern California.
FlightRadar24 offered a free ground station, if you were in an area where they wanted coverage. I didnāt qualify for that, but was attracted to the free Executive Membership for contributing a pi-based station I had a pi3, basically unloved, so I decided to dedicate that to FR24. Shopping for kit, I found the FlightAware receiver, so I went with this complete setup.
After I get it stabilized, I might add a feed for FR24.
I prefer the forum and friendly nature of Flightaware, FR24 does give more information on the app plus, as I am based in UK (currently in CA) and have a friend in US the FR24 web page has useful bookmarks for switching locations.
Geffers
Thatās very easy to do now, connecting the FR24 to the BeastS 127.0.0.1:30005 port. And all the improvements on the FA side will automatically transfer.
I still donāt understand why I did what I did. ![]()
[PiAware - build your own ADS-B ground station for integration with FlightAware - FlightAware](http://Build Page)
Required
Why is this antenna listed on the build page, if it is the wrong length?
I recognize that the 45° spider ground plane is the optimum signal strength pattern in my environment, especially since I am in a valley. But why is the 67mm length so much better than the 170+loaded antenna that is being recommended on the build page?
I am satisfied with the pattern and range that I have now. I wanted to see more to the northeast, but line of sight, that isnāt going to be possible for low altitude flights, regardless of antenna.
On the other hand, it bugs me that I have a pretty little antenna piece sitting on my desk, unused.
I would have been better served by buying just a cable, and using the tip of the coax for my spider.
(That might have been more expensive than my $7.99 3 meter cable with antenna.)
Well if you buy from ebay thatās what you get.
Just because the seller says itās for 1090MHz it doesnāt mean it is ![]()
There are some versions sold as 1090MHz antennas on ebay that are actually decent.
I got an ebay antenna which is actually as good as the spider:
(https://www.ebay.de/itm/253915016420)
@abcd567
Have you ever measured one of those antennas with the VLA?
Actually, I donāt buy from eBay. That is the antenna that was listed on the build page, and the one I bought from an Amazon seller.
Wouldnāt the pattern of your antenna be flatter than a spider?
Because Iām in a valley, the upward angle from the spider is better, I think.
