If I have a 5dbi power antenna installed and I change it to a 9dbi one, would I have more coverage and reach more aircraft on my receiver?
That depends on your location, if you are limited by geographical features ( mountains etc.) the effect might be limited.
Otherwise it should improve but the main factor is the location
It highly depends on your environment.
If you are surrounded already by moutains which limits your range, it’s very unlikely that an antenna swap in this power range would make a difference.
I started with a 3dB one, changed over to the 5dB of Jetvision, finally i ended up at 7.5dB Vinannt.
While it was a slight increase of coverage, the 5dB and the 7.5dB returned the same results.
