Well its taken the best part of two years for me to get round to comparing my existing AirNav FlightStick vs. FA ProStick Plus but as it really is as easy as Plug & Play I thought I’d give it a go before I start updating any of the software as it would be good to retain a baseline to compare against.
So using SkyAware on the LAN I took a screenshot of the current green ANFS and this is what I saw;
Aircraft: 256
Positions: 225
Messages: 1946.2/sec
Shutdown the Pi, swapped them over and first of all noticed how big the blue FAPS+ was. So big in fact that it impacted the small USB->microSD Card adaptor I keep in one of the slots to the point where it wouldn’t fit into any of the three remaining slots! Not the end of the world as I can always put one of the USB devices on a short extension cable much as I hate using extensions/adaptors of any sort but easy enough to do.
Switched on the Pi and gave it 5 or 6 minutes to settle but the performance seemed dismal compared to the AN dongle to the point where I’m wondering if there is a problem with the FA dongle? Problem is I bought it nearly two years ago so way past its return date. You can see the difference here;
Aircraft: 148
Positions: 90
Messages: 273.9/sec
Over 100 aircraft and 1,600+ messages/sec lower? That can’t be right can it?
I regularly see over 300 aircraft and 2000 messages/sec at various times of the day using the AN device and was expecting the FA device to be at least the same but probably better so it was a shock to see this.
I swapped back to the AN dongle and after a few minutes took another screenshot in case I had inadvertently disturbed something that affected the readings but it went back close to what it was before;
Aircraft 275
Positions: 224
Messages: 1827.4/sec
What could possibly cause this? Both AN & FA were used without filters as I believe they already have filters and an LNA built-in but I do have the FA Blue 1090MHz filter here if I ever get round to trying it although I don’t expect to see that make up the difference.
I also have an AirSpy Mini and R2 that I would like to try but this would entail a complete reconfiguration of the Pi and also mean getting the ladders out, dropping the antenna pole, sticking the Kuhne LNA 1090 A TM amplifier inline and fitting the Kuhne bias tee in the loft as the AirSpy only has 4.5v/50mA output vs the 8-15v/130mA the LNA needs so has put me off for the last couple of years!
I still can’t understand why the huge difference between the two dongles unless the FA is faulty or it takes much longer to ‘ramp up’ than the AN device. Maybe the SMA centre pin is not making a good contact with the FA device but I didn’t delve any deeper today.
I might take another look tomorrow to prove/disprove todays findings but I’m really keen to update the system software first as I mentioned in another thread as it’s long overdue…
-=Glyn=-
