It would work, but you would likely get much better performance with one of Flightaware’s Flight Stick Plus dongles, since it has a filter and pre-amp built in. If you only want it for ADS-B reception, then it’s worth spending the few extra pounds, and the slightly larger size is also a worthwhile tradeoff.
For mobile use range is probably less important so pretty much any dongle should do.
Still wouldn’t use a whip antenna or at least cut the whip antenna to length.
It seems to work ok-ish, I see planes out to 80-100nm pretty consistently, and depending on the time of day/day of week, anywhere from 0-40 or so aircraft at any given time.
Is this antenna actually not suitable for my use case? Should I be cutting it down to a shorter length?
Currently, I have it installed in a north-facing window on the second floor of my house, sitting on top of a quart sized paint can.
