I use the HttpClient on multiple platforms IOS, Android, Windows and want to use it to connect and download data via this service. this is how far I have got I change the username for my username and the apikey with the one sent in the email, I am getting authentication errors, also don’t know how to pass parameters like airport etc, I just need one working example to get me going.
thank you.
public async Task GetArrivals() {
var message = new HttpRequestMessage();
var content = new MultipartFormDataContent();
message.Method = HttpMethod.Post;
message.Content = content;
message.RequestUri = new Uri(“http://username:apikey@flightxml.flightaware.com/json/FlightXML2/Arrived”);
string result = “”;
try {
using (HttpClient client = new HttpClient()) {
var operation = client.SendAsync(message, HttpCompletionOption.ResponseHeadersRead);
result = await operation.Result.Content.ReadAsStringAsync();
return result.ToString();
} catch (Exception ex) {
if (ex.InnerException.Message.ToString().IndexOf(“ConnectFailure”, StringComparison.CurrentCultureIgnoreCase) > -1) {
return “”;
return null;
You should be able to do something like this:
using System;
using System.Threading.Tasks;
using System.Net;
using System.Net.Http;
namespace ConsoleApplication1
class Program
static var username = "xxxxxxxx";
static var ApiKey = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
static async Task makeRequest()
var ApiBaseUrl = new Uri("https://flightxml.flightaware.com/json/FlightXML2/FlightInfoEx?ident=UAL6");
var credentials = new NetworkCredential(username, ApiKey);
var handler = new HttpClientHandler { PreAuthenticate = true, Credentials = credentials };
var http = new HttpClient(handler);
HttpResponseMessage response = await http.GetAsync(ApiBaseUrl);
response.EnsureSuccessStatusCode();
if (response.Content.Headers.ContentType.MediaType == "application/json")
var rawbody = await response.Content.ReadAsStringAsync();
Console.Write("Got JSON body:");
Console.Write(rawbody);
static void Main(string] args)
makeRequest().Wait();
Thanks very much for the reply, sorry for the delay in reading the post I did not get a notification of the post via email so I just by chance had a look and found the reply.
This works thanks, now I am using enroute and need to if possible work out the inbound terminal number as there is 5 in total in heathrow, if this is not possible is there a list somewhere I can pull down with flight information and what terminal that comes into?
thanks for your help.
