Wifi Not Working on 10.1?
I must be missing something here, but since I’ve re-imaged to 10.1, I cannot get my unit to connect to Wifi.
  • I am using a Raspberry Pi 3 B
  • Re-imaged the SD card
  • Edited Piaware-config.txt file with SSID and Password
  • Double checked for accuracy and confirmed correct
  • Added original feeder-id to bottom of piaware-config.txt
Pi still will not connect to WiFi. Plugged into monitor and screen shows:
wlan: down
This has to be easy, but what am I missing? I’ve even re-imaged several times, but it seems the only way to connect is via a wired connection.
(24 May 2025)
I am experiencing exactly the same problem. I have a Pi 3 B that was successfully running piaware 8.2x for several years.
I have reimaged the SD card several times. I have tried BOTH wired and wireless as well as the default instructions that come with the 10.1 install (which has no mention of adding static/dynamic IP, selecting between wired and wireless).
For the wired, I added the following to the piaware-config.txt file:
wired-network yes
wiredtype static
wired-address 192.168.1.106
wired-netmask 255.255.255.0
wired-broadcast 192.168.1.255
wired-gateway 192.168.1.1
wired-nameservers 192.168.1.1
connected to an ethernet cable and started. pinging shows no route. router indicated the piaware device is not on the network. So that didn’t work.
Tried wireless:
wireless-ssid Betelgeuse
wireless-password “long password not shown here”
static IP configuration
wireless-type static
wireless-address 192.168.1.106
wireless-netmask 255.255.255.0
wireless-broadcast 192.168.1.255
wireless-gateway 192.168.1.1
wireless-nameservers 192.168.1.1
Same thing: started the device and neither ping or the router show the device as connected.
Anyone from FlightAware have any ideas on what is happenings/
I’m experiencing the same problem.
The configuration that worked under v9 does not work in 10.1.
I am no programmer, but I feel confident that there’s a bug in the software somewhere. The reason being is I was able to re-image to PiAware 8.2, added my wifi info into piaware-config.txt, booted up while connected to the monitor and saw a wifi connection after a minute or two.
My stats page shows info is now feeding to FlightAware, albeit with an anomaly notification that 10.1 is now current.
Do your wifi SSIDs or passphrases contain non-alphanumeric characters, or contain spaces? There’s a bug report in github issues about ' not being correctly handled, and it sounds like there might be more widespread problems with escaping quotes/spaces/etc
In my case, no. But, I did see that same report on GitHub.
Yes, my password has spaces. I’ve tried both ’ and " with no joy.
To get you Pi online (while you wait for a fix), can you setup a guest account on your wifi (with a restricted charactor set) and point your Pi to that.
It’s not ideal, but might get you going.
That is certainly an option. I, personally, would shy away from that approach because when flightaware gets the problem solved, it is going to require a new image file that will have to be installed, along with the attendant -config.txt updates. Not a big deal, just not something I would do.
My password is just mixed case letters and numbers.
I have the same problem - wlan0 down. Was working fine on the remote upgrade to 10.0.1 but when I re-imaged the card to 10.1 and put the same settings in my piaware-config with the feeder-id added, I see wlan0 down and eth0 down. My feeder is down until this gets fixed.
The is always other options than the piaware image.
Example 1:
Raspberry Pi OS + package install: https://github.com/wiedehopf/adsb-wiki/wiki/Raspbian-Lite:-ADS-B-receiver
Example 2:
Premade image with webinterface for configuration: http://adsb.im/
There are more but just to name two.
I can confirm the same issue others are reporting. Wireless only works when configured to use dhcp. Any/all attempts to configure with static address fails.
We’ll look into this asap. I’m going to assume this issue is also present on 10.0 and 10.0.1 SD card images but if anyone has a report of it working fine on those versions, let us know.
I have set static IP in my router.
Doesn’t seem to be the case with 10.0.1. I re-imaged from 8.2 and then updated to 10.0.1 via the “Update and Restart Piaware” command from the stats page. That unit is successfully connected to FlightAware on Wifi and operating fine.
I just tried the Update and Restart and it did not work. I even tried to reimage from scratch and it was worse. I am using ethernet connection and I could not create an SSH file or copy over the config file as in Windows the image directory looked all *&%^%&%%^&%. It is back to 8.2
EDIT .. 8.2 works fine. My fan on my Raspberry Pi will not even work on 10.x but 8.2 looks to be fine.
The SD card image 10.1 is based on Bookworm, and has an App called “Network Manager”. You can configure STATIC IP using it’s utility “nmtui” (network manager text-based user interface)
NOTE
If the first method given below fails, then try alternate method given in the next post below.
FIRST METHOD
STEP-1:
Start the utility by following command:
sudo nmtui
You will get this:
STEP-2:
Highlite “Edit a Connection” and press Enter Key. On the new screen, select “Wi-Fi Wireless”, then use arrow keys to select “Edit”. See screenshot below. Press Enter Key.
STEP-3:
When you complete step-2 and press Enter Key, you will get following screen:
STEP-4:
When you complete step-3, you will get following. Select “Manual” and press Enter Key
STEP-5:
After you complete Step-4 and press Enter Key, next select “Show” and press Enter Key.
STEP-6:
On completion of Step-5 and pressing Enter Key, you will get following screen. Press “Add” and fill up the details (static IP address, DGateway address, DNS address), scroll down to OK button at bottom-right, and press Enter Key. On next screen, scroll down to “Quit” and press Enter Key. DONE.
ALTERNATE METHOD
If metdod given in above post (“Add a connection”) does not succeed, then try following method (“Activate a connection”).
STEP-1:
Issue following command
sudo nmtui
A window shown below will open. Select “Activate a connection” and press Enter Key.
STEP-2:
When you press Enter Key at the end of Step-1, following window will open. Scroll down till you see SSID of your WiFi. Select it and press Enter Key.
STEP-3:
When you press Enter Key at end of Step-2, A dialog will open “Connecting”. After a while a new dialog will open asking for your WiFi password. Enter the password and press Enter key.
Hi all,
We’ve pushed a new image 10.2 that should fix these wifi issues.
Side note:
NetworkManager expects any \ to be escaped; so we added logic to escape them automatically.
It seems like that’s the only special character that needs any special treatment.
