Hi,
Newbie here, so gently please ![]()
New Raspberry Pi 4 2GB. Bought with Piaware SD install. Netgear Orbi Router home network works a treat with everything else.
Raspi repeatedly drops wifi randomly with “carrier lost”. Maximum connection is about 1 hour. Minimum 10 secs.
iwconfig gives
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:“Wi-Fi Network”
Mode:Managed Frequency:2.472 GHz Access Point: 3C:84:6A:51:45:9F
Bit Rate=150 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-23 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:16 Invalid misc:0 Missed beacon:0
eth0 no wireless extensions.
Worked my way tenaciously thru google and this site trying everything mentioned, anywhere.
power saving off.
IPv6 disabled
noarp
All to no avail!
Typical syslog extract (repeated ad nauseam)
Sep 14 16:33:18 piaware kernel: [ 6218.338762] brcmfmac: brcmf_cfg80211_scan: Connecting: status (3)
Sep 14 16:33:34 piaware dhcpcd[740]: wlan0: carrier acquired
Sep 14 16:33:34 piaware dhcpcd[740]: wlan0: IAID 32:c6:a4:94
Sep 14 16:33:34 piaware dhcpcd[740]: wlan0: rebinding lease of 192.168.1.35
Sep 14 16:33:35 piaware dhcpcd[740]: wlan0: leased 192.168.1.35 for 86400 seconds
Sep 14 16:33:35 piaware avahi-daemon[274]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.35.
Sep 14 16:33:35 piaware avahi-daemon[274]: New relevant interface wlan0.IPv4 for mDNS.
Sep 14 16:33:35 piaware avahi-daemon[274]: Registering new address record for 192.168.1.35 on wlan0.IPv4.
Sep 14 16:33:35 piaware dhcpcd[740]: wlan0: adding route to 192.168.1.0/24
Sep 14 16:33:35 piaware dhcpcd[740]: wlan0: adding default route via 192.168.1.1
Sep 14 16:33:35 piaware dhcpcd[740]: wlan0: soliciting an IPv6 router
Sep 14 16:33:35 piaware dhcpcd[740]: ipv6nd_startrs1: Address family not supported by protocol
Sep 14 16:33:36 piaware ntpd[803]: Listen normally on 12 wlan0 192.168.1.35:123
Sep 14 16:33:36 piaware ntpd[803]: new interface(s) found: waking up resolver
Sep 14 16:35:01 piaware CRON[8349]: (root) CMD (/usr/local/bin/checkwifi &> /dev/null)
Sep 14 16:37:54 piaware dhcpcd[740]: wlan0: carrier lost
Sep 14 16:37:54 piaware avahi-daemon[274]: Withdrawing address record for 192.168.1.35 on wlan0.
Sep 14 16:37:54 piaware avahi-daemon[274]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.35.
Sep 14 16:37:54 piaware avahi-daemon[274]: Interface wlan0.IPv4 no longer relevant for mDNS.
Sep 14 16:37:54 piaware dhcpcd[740]: wlan0: deleting route to 192.168.1.0/24
Sep 14 16:37:54 piaware dhcpcd[740]: wlan0: deleting default route via 192.168.1.1
Sep 14 16:37:56 piaware ntpd[803]: Deleting interface #12 wlan0, 192.168.1.35#123, interface stats: received=0, sent=0, dropped=0, active_time=260 secs
Tried a different sd card with a Etcher image of 3.8.1.
Default settings. Still the same issue. Drops repeatedly.
Then tried FR24 image instead to see if I had a dodgy wifi chip.
Using FR24 image on new SD card I have rock solid wifi connection for hours at time.
So, to get to the point!!
I think there is something about the 3.8.1 image build that doesn’t play nicely with ?my Netgear mesh wifi? I see one similar comment on the forums - but no solution
I am a complete novice in Linux and networking so there has been a huge amount of learning, and trial and error. Beginning to wonder if I’m going mad!
I can use wired connection for now (no problems, rock solid) but would dearly love to get wireless working, as the best location for my antenna is in the middle of a field and I wanted to set up a solar powered remote site, which obviously I can’t cable to, so need reliable wifi !
In desperation I now post here, to see if anyone has any guidance to offer as to where I go from here?
I see that dhcpcd is under active development and wonder if a newer version of that may help, but I’ve absolutely no idea how to do that or if its even possible without wrecking the install.
Any help gratefully received
Pretty please ![]()
ps tried DHCP and static IP address. No difference. Still “wlan0 carrier lost”
