My name is Stephan, I come from northern Germany and have only been running a feeder for a few weeks.
The problem I have is that the aircraft displayed in the local FlightAware web page of the local feeder do not match what I see in the Virtual Radar Server Website. When I see about 30 aircraft on the feeder website, I see 2-4 on the Virtual Radar Server website.
My goal is to get an overview of how far the range will change when I replace the antenna cable in the next few weeks. I would like to create polar plots and compare them with each other.
I think I have certainly configured something incorrectly on the VRS and hope to get help here.
I suspect you only have VRS making one single connection to dump1090-fa on port=30105. That port does provide mlat, but it does NOT provide the normal ads-b traffic. To display everything in VRS you will want to set up two separate “receiver” connections in VRS, one for port=30005 and the second for port=30105. Then use the VRS “Merged Feeds” section to combine the two feeds. Finally, in the web view you can select either a single feed or the merged feed.
Be careful with the polar plots. If you want an accurate plot of actual positions that you are receiving you might want to rely on the polar plot for the 30005 port. The merged feed will exaggerate your range.
The VRS documentation covers the merged feed options very well. It’s a very easy fix.
I rarely post here to FA, but you will probably have better luck in the FA “ADS-B Flight Tracking” section and not the General section.
It’s not quite a polar plot but i like it even better to be honest.
You can filter for altitude if you like and it will not show parts of the traces that aren’t in the altitude range.
Also you have a comparison to the heywhatsthat estimated radio horizon for 1090 MHz.
