And is it sufficient to pull only the files in the public html folder or do i need the subfolders too?! Ive set up your mod last night over juciessh on my phone ( not allowed to fiddle around with that anymore because of girlfriend… ) and ignored the folders but im wondering because the countryflags are working and i have no /flags/ folder in my dump1090/public folder?!
Edit:next question. …
I cant see throu the information from dump1090 on my phone. If i clean the cache from the Browser it is working until i click on the settings button… after that the map will get squished to the left
@idh, could you list what you did exactly? I’m trying to get this setup on top of a clean install of JP’s image but I’m having some difficulties following what I need to do.
I just attempted to install this overtop of the most recent (today’s) version of JP’s setup script. map fails to load. Just sits with the spinner spinning away on the map.
Hi usafpride, you need to add a few lines to config.js manually. Best to check the online version and compare this to your local version and add the lines at the end that are missing in your local file.
Your browser should have a javascript console for debugging and to see what is going wrong. There may still be a variable missing that is not defined in config.js.
I have tried it on Raspbian Jessie Light and on Piaware latest image. If you have doubts, then please try installing “dump1090-mutability v1.15~dev” using jprochaza’s automated scripts.
You have posted a link to your screenshot. I will now post your map screenshot to display directly in this post. This makes it easy & quick for others to understand the situation. It is very clear from your screenshot that the center of range rings and terrain limit rings is near Cambridge, UK, which the correct location of receiver. These are the two things installed with dump1090-mutability 1.15~dev. What is off-center is the maximum range curves at different flight levels, which are centered at Amstardam, and this center is determined by configuration settings in lignumaqua’s files you have downloaded from github.
