I’ve entered the registration as it is, i.e. C-GRAI.
Searching for pictures for C-GRAI returns pictures for CGRAI and excludes my uploaded pictures under C-GRAI.
This is a bug.
Whey not removing any dash in the registation provided before saving the uploaded picture to the database if it is not to be process correctly and left as orphan in the system?
Also, how to edit/change that picture so it is filed in your database as “your way” so it is found when someone searches for either CGRAI and C-GRAI, since in this instance, your search functionnality do “remove” the dash entered by the user… same logic should be implemented when registation is inputted for a picture.
PS can someone edit that photo? Else I’ll delete it, but how, the system does not allow for this neither…
When on the picture page (while logged in), at the bottom under the Photo Tags section I remove the dash from the registration and leave the rest as is. When clicking on “SAVE” it says “Invalid aircraft type”… but I did not change it, the Aircraft Type box already contains DHC8.
If I can help further, and if someone can edit the registration tail of this picture?
No idea… but that’s what is (was) there, I’ve changed it and the tail as well. Some more checks and validation maybe on the photo upload form would be required.
