Touch wood since Yesterday I have had no further issues and as an added bonus MLAT is green a lot more than it used to be.
I ended up replacing Pi3 (twice), replaced power supply, adding a cooling fan to the Pi, writing a fresh ADSB.IM image to a brand new unused MicroSD card.
Yeah if you want a solid system, just get a pi4 with a passive cooling case.
That generally works pretty well.
Just as a final note on pi3s:
Testing some frequency limiting on my model:
Added to /boot/firmware/config.txt / applied with a reboot.
# Limit frequencies
arm_freq=800
core_freq=250
over_voltage=-4
That seems to have helped a bit.
Limiting the number of aggregators to only a handful might actually be the best thing you can do.
Or just disabling MLAT.
Both will reduce the CPU usage which reduces power usage which will make the pi3 work better.
Interestingly, I built a Pi 3 for my father the exact same as mine, and it developed this issue today, mine so far has not (Mine has been running for ~3 months but I only updated to the newest image in the last ~3 days)
We both have two SDRs on a powered USB hub. Pi 3 runs both. Latest image on each.
What SDRs are you using?
