Hello,
I’ve noticed an unexplainable drop from time to time. I was able to catch it and save graphs. Do any of the forum experts have any ideas as to what’s happening?
Setup
FlightAware 1090 Antenna → N->SMA adapter > RTL-SDR LNA → LMR400 10ft cable SMA → 10inch RG361 whip → RTL-SDRv3 → Powered USB hub → old MacBook Pro w/ Debian 11 Bullseye. I’m also running another dongle for 978 on the same USB hub.
Confirmed decoder has been up since I last restarted it to adjust gain.
$ sudo systemctl status readsb.service
● readsb.service - readsb ADS-B receiver
Loaded: loaded (/lib/systemd/system/readsb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/readsb.service.d
└─bias-t.conf
Active: active (running) since Fri 2022-02-25 21:18:39 CST; 19h ago
Docs: https://github.com/wiedehopf/readsb
Process: 341957 ExecStartPre=/usr/local/share/adsb-wiki/biastee/rtl_biast/build/src/rtl_biast -b 1 (code=exited, status=0/SUCCESS)
Main PID: 342098 (readsb)
Tasks: 8 (limit: 9185)
Memory: 25.6M
CPU: 3h 13min 5.986s
CGroup: /system.slice/readsb.service
└─342098 /usr/bin/readsb --device 0 --device-type rtlsdr --gain 25.4 --fix --ppm 0 --lat 36.**** --lon -87****.>
Feb 25 21:18:39 macbookold readsb[342098]: Using lat: 36.***, lon: -87.***
Feb 25 21:18:40 macbookold readsb[342098]: Preparing error correction tables.. done.
Feb 25 21:18:40 macbookold readsb[342098]: 30002: Raw TCP output port 30005: Beast TCP output port
Feb 25 21:18:40 macbookold readsb[342098]: 30003: SBS TCP output ALL port 30004: Beast TCP input port
Feb 25 21:18:40 macbookold readsb[342098]: 30104: Beast TCP input port
Feb 25 21:18:40 macbookold readsb[342098]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000101)
Feb 25 21:18:40 macbookold readsb[342098]: Detached kernel driver
Feb 25 21:18:40 macbookold readsb[342098]: Found Rafael Micro R820T tuner
Feb 25 21:18:40 macbookold readsb[342098]: rtlsdr: tuner gain set to 25.4 dB
Feb 25 21:18:40 macbookold readsb[342098]: Allocating 16 zero-copy buffers
