Upgraded my raspberry pi. I need to disassociate my old raspberry pi feeder instance (b8:27:eb:9b:c7:1e) from my account timevex. The new feeder instance is (b8:27:eb:d7:bc:90) but I can’t see any stats from that feeder, it seems to be stuck looking for stats to come in from the old defunct feeder ( b8:27:eb:9b:c7:1e)
Can’t get the old piaware instance it to disappear and the new (b8:27:eb:d7:bc:90) one to appear on my stats page
Site identifier: b8:27:eb:9b:c7:1e **<–old instance **
Internet IP: 73.187.62.162
Site local IP: 192.168.1.11
Web interface: view live data (requires local network connection)
Data Feed: Live - 40 minutes ago
Feeder Check-in: Live - 40 minutes ago
Longest Streak: 11 days (08-Aug-2016 - Today)
Feeder Type: PiAware (SD Card) 2.1-5
Multilateration (MLAT): Supported / Enabled
I have a similar problem. The RPi I am using was based at a friend’s house, he has been unable to disassociate it from his feed despite repeated attempts - and I have been unable to add it to mine. My friend contacted FA to get the disassociation sorted out more than 10 days ago, and I had a try 3 days ago - he had one reply and no fix, I had no reply and no fix.
I’m sure that you will appreciate just how impressed we both are with FA support.
That is a different problem, though. You can disassociate it yourself directly from the stats page. Make sure piaware is stopped when you do this. It will tend to reassociate with a logged-in-to-the-website user from the same IP, so you may want to log in to the website as yourself from your friend’s house while you do this to avoid it reassociating with your friend’s account.
The OP’s problem does not sound like a problem with disassociation since they are independent feeders.
Bad site 41202 follows:
I also need to disassociate (unclaim) this 41202 site:
Site identifier: a1e0364f-0d8b-468b-8083-e39f5212af8c
Internet IP: 73.136.231.95
Site local IP: 192.168.0.179
Good site 40775 follows:
I was using dhcp and it changed my router IP address to a new address which I want to keep:
Site identifier: c76de25a-ad33-4e4d-92ce-78e6d441232c
Site local IP: 192.168.0.180
After about 30 hours I logged in my stat site and found a sentence about my old site not providing any data and it asked if I wanted to remove the site. The sentence was a hyperlink which I clicked on. Thank you for providing that Mr Programmer. I appreciate it.
