so I’ve been running piaware for over a month on my server, and it’s been doing great. However, during this reinstallation, i’m running into a problem and out of options.
I’ve decided to FINALLY note that i’ve been running piaware nefariously behind a Zentyal 4.1.5 Active Directory server (this server is built on & runs on ubuntu Server 14.04LTS). It did fine for a month, then a typo during an update, and well, i’ve been running around with my head on fire for 4 days now.
since I had to reinstall zentyal from scratch, I decided to take advantage of switching from 32 to 64 bit architecture. If this is a problem, go figure…
SO, since the switch, i’ve been running into this error whilst installing Dump1090 muta
dpkg-shlibdeps -Tdebian/dump1090-mutability.substvars debian/dump1090-mutability/usr/bin/dump1090-mutability debian/dump1090-mutability/usr/bin/view1090-mutability
dpkg-shlibdeps: error: no dependency information found for /usr/local/lib/librtlsdr.so.0 (used by debian/dump1090-mutability/usr/bin/dump1090-mutability)
dh_shlibdeps: dpkg-shlibdeps -Tdebian/dump1090-mutability.substvars debian/dump1090-mutability/usr/bin/dump1090-mutability debian/dump1090-mutability/usr/bin/view1090-mutability returned exit code 2
make: *** [binary] Error 2
dpkg-buildpackage: error: debian/rules binary gave error exit status 2
[exit] Error building dump1090-mutability, script will now exit.
root@hscserver:/home/hscadmin/build/d49d2d4d850fb2dd279d#
I’ve looked into librtlsdr, and it is where it’s supposed to be. gedit gives me an error where I can’t read the data, so I didn’t know what that meant.
There was a similar thread to this, and I tried as many options and fixes as listed in there, including apt-get remove, purge, reinstall, as well as physically deleting librtlsdr from the server. I also added i386 architecture to my dpkg list (i had a similar issue with Teamviewer), and deleted the lot and tried again. I also tried an automated script I’d found on FA, but with the same result. Assistance in the matter would be greatly appreciated. Thanks!
-Ramos
