Fundamentally the problem is the same one as in this thread:
The variable names for altitude, speed and vertical rate have changed in 3.6.2
Thanks all for the comment
so itās clear from you comment that field names were changed.
LawrenceHill,
can you explain please : āamend procedureā in the mentioned thread : do I have to insert the code or replace some code, this is not clear to me
Sorry, I was not trying to say that you should insert or replace code with that in the other thread.
I was just trying to give a starting point for the sort of modification that would be needed.
If you are using dump1090-mutability but want to use the java script from the latest dump1090-fa you will need to modify the updateData procedure in planeObject.js to allow it to use the variable names used in dump1090-mutability.
Unfortunately, I am not familiar with mutability so cannot tell you the exact mods that are needed but it seems that @abcd567 is. Hopefully the information may point him in the correct direction.
The quoted thread relates to a non-standard set of files (GitHub - alkissack/Dump1090-OpenLayers-html: Modifications to the Openlayers html files (part of the dump1090-fa branch)). If you are on standard code, the changes are probably in the same file (planeObject.js) and same procedure (updateData)ā¦
If your looks like:
if (typeof data.altitude !== "undefined")
this.altitude = data.altitude;
if (typeof data.vert_rate !== "undefined")
this.vert_rate = data.vert_rate;
if (typeof data.speed !== "undefined")
this.speed = data.speed;
then change it to be:
if (typeof data.alt_baro !== "undefined")
this.altitude = data.alt_baro;
if (typeof data.geom_rate !== "undefined")
this.vert_rate = data.geom_rate;
if (typeof data.gs !== "undefined")
this.speed = data.gs;
Relevant part (updateData procedure) of planeObject.js
in dump1090-fa ver 3.6.2
// Update our data
PlaneObject.prototype.updateData = function(receiver_timestamp, data) {
// Update all of our data
this.messages = data.messages;
this.rssi = data.rssi;
this.last_message_time = receiver_timestamp - data.seen;
// simple fields
var fields = ["alt_baro", "alt_geom", "gs", "ias", "tas", "track",
"track_rate", "mag_heading", "true_heading", "mach",
"roll", "nav_altitude", "nav_heading", "nav_modes",
"nav_qnh", "baro_rate", "geom_rate",
"squawk", "category", "version"];
for (var i = 0; i < fields.length; ++i) {
if (fields[i] in data) {
this[fields[i]] = data[fields[i]];
} else {
this[fields[i]] = null;
// fields with more complex behaviour
if ('type' in data)
this.addrtype = data.type;
else
this.addrtype = 'adsb_icao';
// don't expire callsigns
if ('flight' in data)
this.flight = data.flight;
if ('lat' in data && 'lon' in data) {
this.position = [data.lon, data.lat];
this.last_position_time = receiver_timestamp - data.seen_pos;
if (SitePosition !== null) {
var WGS84 = new ol.Sphere(6378137);
this.sitedist = WGS84.haversineDistance(SitePosition, this.position);
this.position_from_mlat = false;
if (typeof data.mlat !== "undefined") {
for (var i = 0; i < data.mlat.length; ++i) {
if (data.mlat[i] === "lat" || data.mlat[i] == "lon") {
this.position_from_mlat = true;
break;
// Pick an altitude
if ('alt_baro' in data) {
} else if ('alt_geom' in data) {
this.altitude = data.alt_geom;
} else {
this.altitude = null;
// Pick vertical rate from either baro or geom rate
// geometric rate is generally more reliable (smoothed etc)
if ('geom_rate' in data) {
} else if ('baro_rate' in data) {
this.vert_rate = data.baro_rate;
} else {
this.vert_rate = null;
// Pick a speed
if ('gs' in data) {
} else if ('tas' in data) {
this.speed = data.tas;
} else if ('ias' in data) {
this.speed = data.ias;
} else {
this.speed = null;
in dump1090-mutability ver 1.14
// Update our data
if (typeof data.track !== "undefined")
this.track = data.track;
if (typeof data.lat !== "undefined") {
this.position = new google.maps.LatLng(data.lat, data.lon);
this.sitedist = google.maps.geometry.spherical.computeDistanceBetween (SitePosition, this.position);
if (typeof data.flight !== "undefined")
if (typeof data.squawk !== "undefined")
this.squawk = data.squawk;
My planeObject.js looks like :
in dump1090-fa ver 3.6.2`
I will try look into this part, but I infact Iām not a javascript specialist at all
OK, found hack
Altitude works, Speed still not
(1) Opened file planeObject.js
for editing
sudo nano /usr/share/dump1090-mutability/html/planeObject.js
(2) Pressed (Ctrl+w) keys, typed Pick a speed
Added
} else if ('altitude' in data) {
just above
} else {
The modified code becomes
// Pick an altitude
} else {
(3) Pressed (Ctrl+w) keys, typed Pick a speed
Added
} else if ('speed' in data) {
just above
} else {
this.speed = null;
// Pick a speed
if ('gs' in data) {
} else {
this.speed = null;
I have done following in the code based upon the information in the other replies :
regarding altitude : replaced ānullā with ādata.altitudeā
regarding vert rate : replaced ānullā with ādata.vert_rateā
regarding speed ;more tweaking by putting :
see complete change hereunder :
// Pick an altitude
} else {
} else {
Pick a speed
if ('gs' in data) {
the result is better but not complete : still missing the speed
see screenshot
any further suggestions or remarks that this can be better or should not be done ?
I think our replies crossed
Both of us independently found the same solution.
I have noticed you typing a reply while I was typing mine.
Good work.
@Patrius
Could you solve the Speed issue?
I am trying, but still no solution.
I dont understand why the hack which worked OK for Altitude, fails for Speed
@wiedehopf
@LawrenceHill
@Akissack
@Patrius
(1) Rename original folder html
to original-html
This will preserve original folder and enable you to revert in case something goes wrong.
sudo mv /usr/share/dump1090-mutability/html /usr/share/dump1090-mutability/original-html
(2) Clone dump1090 ver 3.5.3
cd ~/
git clone https://github.com/flightaware/dump1090.git
cd ~/dump1090
git fetch --all
git reset --hard 232a64e
HEAD is now at 232a64e Prepare for 3.5.3 release
(3) Copy folder public_html
to folder dump1090-mutability
folder, renaming copy html
sudo cp -r ~/dump1090/public_html /usr/share/dump1090-mutability/html
(4) Rename file index.html
to gmap.html
sudo mv /usr/share/dump1090-mutability/html/index.html /usr/share/dump1090-mutability/html/gmap.html
(5) Clear browser cache (Ctrl+Shift+Delete), and reload (Ctrl+F5)
(a) Delete ver 3.6.2 folders dump1090
and html
(b) Do not perform step (1) above as you have already done it.
sudo rm -rf ~/dump1090
sudo rm -rf /usr/share/dump1090-mutability/html
Forum member @evangelyul has posted this very useful tweak here:
Hi,
the RPi I have is configured with a standard image and then implement the software/hardware I like
So regarding testing the influence of the gain I take scenario āOptimize-Gain-dump-fa-on-Raspbian-Jessieā
My system is stretch I think:
Linux 4.14.62-v7+ #1134 SMP Tue Aug 14 17:10:10 BST 2018 armv7l
When I look into the script (I donāt know python, just guessing here), it looks for the config file : /etc/default/dump1090-fa, which I have and changes the line āRECEIVER_OPTIONSā with different gain values to do the tests,
However the line in the script differs from my first line in the config file , so I presume itās ok to change the script and take the parameters from my config file to do the test ?
(I see that some parameters in the script are defined in the āNET_OPTIONSā line.
line in the script :
if line.startswith('RECEIVER_OPTIONS'):
print 'RECEIVER_OPTIONS="--device-index 0 --ppm 0 --gain ' + g + ' --net-bo-port 30005 --net-sbs-port 30003"'
lines in my /etc/default/dump1090-fa :
RECEIVER_OPTIONS="--device-index 0 --gain -10 --ppm 0 --net-bo-port 30005"
DECODER_OPTIONS="--max-range 360"
NET_OPTIONS="--net --net-heartbeat 60 --net-ro-size 1000 --net-ro-interval 1 --net-ri-port 0 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005"
JSON_OPTIONS="--json-location-accuracy 1"
Is this ok to go forward ?
Thanks for any suggestions
Yes, thatās where you change the gain. Note that āg -10ā is just a made-up value that is translated into Automatic Gain Control (analog side).
Supported gain values (29) are usually: 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
If you put another value, it will be rounded to the closest one.
Also you can try adding --enable-agc
to enable digital AGC (not tuner AGC!). Personally I didnāt like it.
After any change do sudo systemctl restart dump1090-fa
to implement.
You can also check the current value by sudo systemctl status dump1090-fa -l
Ok I will , but they are the same (did a comparison in notepad++)
what about the suggestion that I take following parameter out :
its defined in the āNET_OPTIONSā line
