# Tweaks
**URL:** <https://discussions.flightaware.com/t/tweaks/20339>\
**Category:** ADS-B Flight Tracking\
**Created:** [July 24, 2017, 6:49am UTC](https://discussions.flightaware.com/t/tweaks/20339 "2017-07-24T06:49:09Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![abcd567](https://sea1.discourse-cdn.com/flex019/user_avatar/discussions.flightaware.com/abcd567/32/113769_2.png) [@abcd567](https://discussions.flightaware.com/u/abcd567)\
**Post date:** [July 24, 2017, 6:54am UTC](https://discussions.flightaware.com/t/tweaks/20339/2 "2017-07-24T06:54:50Z")
</div>
TWEAK-1: RANGE CIRCLES
**(1) INCREASING NUMBER OF RANGE CIRCLES**
By default, there are 3 circles at 100, 150 & 200 nm.
If you want to add more circles, go to following line in “config.js” and add numbers as shown in red.
sudo nano /usr/share/dump1090-mutability/html/config.js
Press Ctrl+w and type SiteCircleDistances and press Enter key.
The cursor will jump to line below. Add additional circles as shown ib red
SiteCirclesDistances = new Array(50,100,150,200,250,300);
If you have installed dump1090-mutability using JProchazka’s Script, the Cicle diameter will be in km instead of nm due to a bug.
Remove this bug as follows:
In file config.js, scroll down till you find a line
Metric=“false;”
Remove quotes " " (but don’t remove the ; semi colon), so the line becomes
Metric=false;
Save the file config.js, and restart dump1090-mutability
sudo systemctl restart dump1090-mutability
Now clear cache of your browser, and reload/refresh the map in your browser, and you will see the range rings in nautical miles.
**(2) COLORING RANGE CIRCLES ALTERNATE RED/BLUE dump1090-fa version 3.5.0**
```auto
#enter the html folder
cd /usr/share/dump1090-fa/html/
#make a copy of script.js by the name script_orig.js before modifications.
#this way you will have a backup copy in case somrthing goes wrong.
sudo cp script.js script_orig.js
#open file script.js for editing
sudo nano script.js
The last command above will open the file “script.js” for editing
Press Ctrl+w, then type circleStyle , then press Enter key. The cursor will jump to the line:
var circleStyle = function(distance) {
Make changes as shown in red below, save the file and exit the editor.
Reload the Browser to see map with colored circles.
**NOTE:**
Forum is blocking me to post the code. Code below is a screenshot of Word file. Download the Word file containing code to facilitate copy-paste.
[Click here to Download: ColorCircles-dump1090-fa.docx](https://www.dropbox.com/s/kdtsll7oscg3ie1/ColorCircles-dump1090-fa.docx?dl=1)
[https://s20.postimg.org/qhl9lg2t9/Color\_Circle-dump-fa.png](https://s20.postimg.org/qhl9lg2t9/Color_Circle-dump-fa.png)
**(3) COLORING RANGE CIRCLES ALTERNATE RED/BLUE dump1090-mutability version 1.15~dev**
```auto
cd /usr/share/dump1090-mutability/html/
sudo nano script.js
Press Ctrl+w, then type siteCircle, then press Enter key. The cursor will jump to siteCircle.
**NOTE:**
[Click here to Download: ColorCircles-dump1090-mut.docx](https://www.dropbox.com/s/0nwof781qem2hl5/ColorCircles-dump1090-mut.docx?dl=1)
[https://s20.postimg.org/cel3hvccd/Color\_Circles.png](https://s20.postimg.org/cel3hvccd/Color_Circles.png)
_[View the full topic](https://discussions.flightaware.com/t/tweaks/20339)._
