Trying to add my new piaware.... I can't see it :-(
Hello my friends:;
I am trying to add my new piaware feeder to my account.
In my side I think all is OK
Why can’t I a add it?
Thank’s a lot
Here you have piaware logs:
2026-05-02T07:29:45.678026+00:00 sdr piaware[264879]: piaware version 10.2 is running, process ID 264879
2026-05-02T07:29:45.679065+00:00 sdr piaware[264879]: your system info is: Linux sdr 6.12.74+deb13+1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.74-2 (2026-03-08) x86_64 GNU/Linux
2026-05-02T07:29:47.180267+00:00 sdr piaware[264879]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
2026-05-02T07:29:47.326916+00:00 sdr piaware[264879]: Connection with adept server at piaware.flightaware.com/1200 established
2026-05-02T07:29:47.716399+00:00 sdr piaware[264879]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
2026-05-02T07:29:47.723512+00:00 sdr piaware[264879]: FlightAware server certificate validated
2026-05-02T07:29:47.723579+00:00 sdr piaware[264879]: encrypted session established with FlightAware
2026-05-02T07:29:48.181367+00:00 sdr piaware[264879]: logged in to FlightAware as user guest
2026-05-02T07:29:48.182792+00:00 sdr piaware[264879]: my feeder ID is d743b786-870f-4e56-9003-cc697d5851ab
2026-05-02T07:29:48.183244+00:00 sdr piaware[264879]: site statistics URL: Site 273895 ADSB-B Feeder Statistics - FlightAware
2026-05-02T07:29:48.695953+00:00 sdr piaware[264879]: ADS-B data program ‘readsb’ is listening on port 30005, so far so good
2026-05-02T07:29:48.696110+00:00 sdr piaware[264879]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout
2026-05-02T07:29:48.697392+00:00 sdr piaware[264879]: Started faup1090 (pid 264973) to connect to readsb
2026-05-02T07:29:48.697768+00:00 sdr piaware[264879]: UAT support disabled by local configuration setting: uat-receiver-type
2026-05-02T07:29:48.898552+00:00 sdr piaware[264879]: piaware received a message from readsb!
2026-05-02T07:29:48.899622+00:00 sdr piaware[264879]: piaware has successfully sent several msgs to FlightAware!
2026-05-02T07:30:20.180434+00:00 sdr piaware[264879]: 396 msgs recv’d from readsb; 396 msgs sent to FlightAware
2026-05-02T07:35:20.180366+00:00 sdr piaware[264879]: 2110 msgs recv’d from readsb (1714 in last 5m); 2110 msgs sent to FlightAware
2026-05-02T07:40:20.180550+00:00 sdr piaware[264879]: 3944 msgs recv’d from readsb (1834 in last 5m); 3944 msgs sent to FlightAware
You are logged in as a guest on this system so you haven’t claimed it yet.
See step 7 on this page:
If that doesn’t work then install piaware-web on the new system:
install piaware-web as additional package.
Please post output of following command. It will show the source of the piaware-web package:
apt-cache policy piaware-web
Then install that package and open it on the page of the new feeder:
sudo apt install piaware-web
Claim the new feeder ID from the piaware-web page that should display you have an unclaimed feeder.
Thank’s for your reply.
I think it is solved now.
Vamos! Have fun with it.
Yes, it is solved, see screenshots below.
Piaware logs show that your OS is Debian 13 AMD64. Just out of curiosity, want to ask how did you install piaware on it? Flightaware repository does not have package for this OS & architecture.
I am running a linux container under proxmox.
And i installed it using YOUR Scripts !!!
It was very easy and is running like a champ.
Thank’s for your work !
