For a few months, I’ve been running around 44.5 to keep the 3db ratio around 2 to 3.
Lately, I had to drop it down to 32.8 to get it below 3.
My FA antennae is on my roof but I have very tall trees around my house. Starting to wonder if a 50ft pole would be worth it when the leaves come back.
Leaves love microwave and absorb them almost entirely.
Incresing the height of your antenna will increase your maximum range till the antenna reaches a hight slightly above the height of obstructions (neighbor’s houses, tall buildings, tall trees). This height is is optimal as further increase is a huge investment of money, effort, and time, without propotionate benefit in terms of maximum range or number of plane.
Conclusion: don’t use too high a pole. Use only a pole which is just slightly higher than the tallest trees.
… don’t know whether you have an amplifier between antenna and usb-dongle. but if not - and using a passive antenna - i’d suggest first another test for better results. at least at my site i got much more data when going above -3db with gain value ‘-10’ a.k.a. ‘agc’
