Hi there! In the process of possibly replace my RbPi with a more robust home server, I am trying to get ReadSB/Tar1090 to work on Ubuntu Server (24.04). I have come so far as setting up readsb and tar1090 with the excellent scripts, but nginx was a bit difficult and I have paid notice to what needs to be done when using CF for the domain. I get errors as the attached image shows, the interface keeps reloading and some components seem to return 404 messages. Any hint on how to configure tar1090?
If you get the same errors locally this is unrelated to CF.
Run the tar1090 install again and it’ll tell you which config to use.
It generates a config for nginx even so it really shouldn’t be hard.
/data and /chunks aren’t mapped correctly.
Well of course it works. There was some hicup when I ran the script the first time so maybe something happened then. Now SSL and CF is no problem, I´ll try to move the interface from /tar1090 to / but it should not be a problem. Thanks!
