I’ll check for that, abusive i really don’t want to be.
Yeah … getting across hyperbole is complicated in writing.
Also it may have a different connotation depending on your background.
"Are you serious? " would probably have been better in retrospect.
In my mind, that’s what i wanted to get across in the context.
English is not my first language, but i don’t think that’s the issue here, more a difference in approaching this or other forums.
Anyhow enough of that, feel free to step into any of “my” threads any time (well they don’t really belong to me do they?).
I’ll endeavor to choose a more polite tone.
Does anyone currently have the same problem loading the Wikimedia Openstreetmap?
It’s loading but while zooming in there are parts which are not following that properly (see below). I tried cleaning cache&cookies, but it doesn’t change. Other maps are operating normally.
The map is now visible in tar1090 after adding /run/skyaware978 to /etc/default/tar1090_instances It’s working with the ENABLE_978=yes. What is the effect of leaving it?
Well it’s loading all the data twice.
Can lead to the planes jumping around a bit as the data arriving from enable_978 will be delayed by around 1 second.
Thanks for the rapid solution.
With ENABLE_978=yes the planes show as UAT
With ENABLE_978=no planes show as ADS-B
seemed like no planes appeared after changing to 978=no until rebooting pi.
Nice interface
Hi @wiedehopf - not sure if this was intended or not…
I moved the cursor off the window to do other work. It must have found an aircraft on the way out of the window. Anyway it kept following the aircraft for a long way…
