See the edit above for some more explanation why SkyView978 displays them as ADS-B.
Thank you for the new update: it’s great !
What changes did you notice? ![]()
The V button today, and the various improvements of the previous days ;+)
It almost finishes loading over your slow internet now, thanks to the smaller history files.
It’s not quite there, but i don’t want to increase the timeout.
(almost there though)
Anyway 230 history points which is how much it’s loading is perfectly sufficient!
Yes the loading is more quicky with all of these updates !
Is this the planned view?
If yes, i like the previous version more
Uh, forget it. I needed to reload the tab without cache. Now it looks ok.
I am confused on “k” track labels. they are all on top each other
what are they displaying ?
Then zoom in.
And it shouldn’t be too hard to figure out what is displayed ![]()
It would have probably looked ok a second later.
Can look like this directly after loading, it’s somewhat expected.
Ctrl-F5 normally shouldn’t be needed anymore.
Got it, rapidly changing course/speed was what confused my displayed view !
To be clear it’s the same as the extended label by pressing L and O.
Minus the callsign of course.
It’s altitude and groundspeed.
In regards to when a label is printed, that happens when the color of the trail changes based on altitude steps.
It happens more often below 10000 (500 ft interval vs 1000 ft interval above).
I like the various extensions, including the View button.
I do sometimes get confused on what button I have pushed and what is active and what is not. Some thoughts:
Would it be possible to have the button change color if pushed? This would be then for buttons B, V, M, L , K, O ,R.
Another approach could be to change the “Reset Map” button to “Reset All” and reset the map as well as the default values for the small buttons B,…R.
You could also consider adding Only List Aircraft in View in the gear menu.
Just a consideration
That seems like a very sensible idea!
Give it a few days ![]()
I’ve got the new version running on one of my Pis (with stretch installed) - excellent update
However, for the old Pi running the original Raspbian ??, I get the following error message below when I try to install the update:
Any suggestions?
Many thanks
WARNING: The following packages cannot be authenticated!
jq p7zip-full
E: There are problems and -y was used without --force-yes
Failed to install required packages: lighttpd unzip git p7zip-full perl jq
try
sudo apt-key update
What does it say?
What is the output of:
cat /etc/os-release | grep PRETTY
If it’s Jessie, i would suggest starting over with a fresh install of Raspbian Buster Lite.
But i’ll see i can make it work in your case.
You can probably just force the installation:
sudo apt-get install -y --force-yes jq p7zip-full
It is Jessie, but I tried to force the installation as you suggested and it has worked.
Many thanks for the quick reply, and for the further additions to the display, they are excellent
just out of curiosity, what is the output of:
sudo apt-key update
Also i’d recommend you start with a fresh Raspbian Buster Lite image at some point.
It was:
pi@piaware:~$ sudo apt-key update
gpg: key 90FDDD2E: “Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) mpthompson@gmail.com” not changed
gpg: Total number processed: 1
gpg: unchanged: 1
Warning: removed keys keyring /usr/share/keyrings/raspbian-archive-removed-keys.gpg missing or not readable
Thanks for the recommendation of Buster Lite, I’ll take a look at it
