System maintenance for the PI
Hi everyone,
I’ve been running my PI for a few years now and wanted to ask whether I should clear any logs to avoid running into problems. I’m sending data to Flight Aware, FR24 and ADS-B E.
So, in short, are there any commands I can use to give my system a bit of a boost?
Hi and welcome to this forum MTappe
My AI answers you question as follows
❯ A USER ASKS :
WHAT DO WE ANSWER WITHOUT ACCESS TO HIS RPI ?
● General advice for a PiAware/FR24/ADSBX Pi:
# 1. Check disk usage first
df -h
# 2. Clean old apt cache (biggest space hog usually)
sudo apt clean
# 3. Remove old kernels/packages no longer needed
sudo apt autoremove -y
# 4. Clear old journal logs (keep last 7 days)
sudo journalctl --vacuum-time=7d
# 5. Check what’s eating space
du -sh /var/log/* | sort -rh | head -10
# 6. Truncate any bloated logs
sudo truncate -s 0 /var/log/syslog.1
sudo truncate -s 0 /var/log/daemon.log.1
# 7. Check SD card health (read-only test)
df -h /
Key points to mention:
  • dump1090-fa doesn’t accumulate logs — its data is in /run/ (RAM tmpfs), wiped on reboot
  • FR24 feeder can grow /var/log/fr24feed.log — safe to truncate
  • PiAware logs to /var/log/piaware.log — also safe to truncate
  • The real killer is usually /var/log/syslog and /var/log/daemon.log growing over years, plus apt cache
  • journalctl storage under /var/log/journal/ can be huge on old installs
  • A sudo reboot once in a while doesn’t hurt either — clears tmpfs and restarts all feeders cleanly
No “boost” as such — a Pi either works or it doesn’t. But freeing SD card space prevents the system from grinding to a halt when it hits 100%.
HTH
Evangelos
