I am a newbie running a Rasp Pi 4 2Gb with a Pro stick and flight aware 3.8.1 and dump1090-fa. It is a new system and nothing else is running. I normally connect to pi over wifi using VNC viewer or Putty. The system works well but it seems to freeze after exactly 24 hrs give or take a minute or so. After the freeze I cant connect by VNC or Putty. The Pi aware map web page gives the following error-
Problem fetching data from dump1090. AJAX call failed (timeout: timeout). Maybe dump1090 is no longer running? The displayed map data will be out of date.
I need to disconnect power and restart and all is well for another 24 hrs.
I have checked SD card is seated, the power supply is genuine Raspberry, the Pi is on a fixed IP address. I was about to try a full reinstall of all software and try running over a wired connection , as I dont know if this is a wifi issue or hardware/software problem. I thought it was worth asking in case anyone knows if there may be another reason for this as it happens every 24 hours exactly?
Thanks for the suggestion. I have checked my router settings and the ip address is definitely reserved, but I think you have cracked it!
I have 2 Pi’s one dedicated to Pi-hole, and the other one with the problem, running Piaware and dump1090-fa only. Both show as reserved in my router table however, I forgot I am using a Pi as a DHCP server. I checked the Pi-hole settings and leases renew every 24 hrs. I have assigned a static lease now on Pi-hole control panel. Hopefully SOLVED.
… which is related to dhcpcd attempting to defend the assignment of its configured IP (perhaps in this case because the DHCP server has reused the IP elsewhere) and then crashing.
I’m not sure what sdcard image you started from. The piaware sdcard image includes a fixed dhcpcd package, but I don’t think the bugfix has made it into the upstream Raspbian images yet, so maybe that’s the cause of things going bad.
I think you may be right. The Pi froze again this evening.
The Pi came with an SD, NOOBS preinstalled, containing Raspbian. I installed dump1090-fa and Piaware following instructions on this website. I have had a quick look at the thread but it is mostly beyond me. A Piaware sdcard image with the fix looks like the best bet.
I assume all I need to do is follow the instructions in sections 2 and 3 here?
Thats me up and running with a piaware SD card image. I have updated the feeder id to my existing site. I have also reserved the IP address to the Pi-hole server.
I am watching for your results with interest as I think I have the DHCP problem as well. I have resisted doing the SD card image rebuild so far but am beginning to think that it is in my future…
Well, it has been over 36 hours now and my system is still running. I think I must have had the DHCP bug mentioned above. Hopefully it will make it into the next update of Raspbian.
Typical. I spoke too soon. The system froze again about an hour ago. I have restarted but if it happens again, will move to a wired connection to try out.
My Pi aware has just stopped again with the same problem. I am thinking of connecting it to another wifi network. I have an old Netgear router which I could set up and connect my Pi to it wirelessly. Not sure if it will make a difference. It will be a pain changing networks back and forth but better than nothing. Will let you know how it goes.
I have also upgraded to 4.0. Unfortunately during the last two consecutive overnights my system has stopped displaying aircraft on SkyAware but continued to send data to FA via feeder. I also check my router log and do not find anything in it that indicates that internet connectivity was compromised over the two days. I am interested in your results…
Everything is still working well without faults after two weeks or so. I am running my Pi wirelessly to a second Netgear router which is hard wired to my main Vrgin Media (VM) router. The IP of the Netgear router is reserved on the VM router and the Pi IP address is reserved on the Netgear router. It is a bit messy but it works!
