Hi,
This is a possible suggestion for the FA site coverage map that shows station locations.
FlightAware ADS-B Coverage Map
The page currently has filters for these options:
FlightFeeder
PiAware
Radarcape
Note: I believe the Radarcape is probably historical from early Radarcape “direct feeder” days. It does not seem to identify Radarcape direct feeders any longer. It might be worth removing that option possibly.
Suggestion:
Consider adding two new filters as below. Both would default to enabled.
1090 ADS-B (or whatever you want to call it)
978 UAT
This would allow people to view the sites in an area and then deselect the 1090 to view only 978 UAT sites. Yesterday in another message thread I was viewing sites online and realized it is a bit tricky to quickly identify those feeding 978 UAT. I had to manually select a station and then look at the “Feeder Mode: Mode-S (1090 MHz) and UAT (978 MHz)” to spot the 978 UAT feeders.
FA clearly already has the data needed for this. Adding a 1090 and 978 filter to the page would be VERY useful and might help to increase interest in additional 978 coverage. The status of the 1090/978 would simply be based on the “Feeder Mode: Mode-S (1090 MHz) and UAT (978 MHz)”. It would indicate a station is configured for 1090/978, but of course not that they are actually receiving and uploading 1090/978.
If not too difficult to do this, I believe it would be a valuable feature.
Thank you,
-Dan
