stuck on "reading samples in async mode"
Hi All
I have dump978 running with a 978Mhz spider antenna. When I run the pipeline in Linux, I get the message:
todd@todd-VirtualBox:~$ cd dump978b/dump978
todd@todd-VirtualBox:~/dump978b/dump978$ rtl_sdr -f 978000000 -s 2083334 -g 48 - | ./dump978 | ./uat2text
Found 1 device(s):
0: Generic, RTL2832U, SN: 77771111153705700
Exact sample rate is: 2083334.141630 Hz
Sampling at 2083334 S/s.
Tuned to 978000000 Hz.
Tuner gain set to 48.00 dB.
Reading samples in async mode…
It stays stuck here and I see no data
Any thoughts?
Todd
Is your goal to display it on a dump1090 host? If so, change it to:
/usr/bin/rtl_sdr -f 978000000 -s 2083334 -g 48 - | /usr/local/dump978/dump978 | /usr/local/dump978/uat2esnt | /bin/nc -q1 127.0.0.1 30001 &
If your dump1090 isn’t local, change the IP address as needed…and adjust your local paths as needed.
Todd,
not many aircraft equipped with UAT yet, so you may not getting any UAT “hits” and you probably not within line of sight from ADS-R station. I am seeing fewer than 10 UAT planes a day. Let it run for a while.
Alex
I am physically quite close to the nearest antenna/station. Normally it is humming with activity.
Todd
Todd,
sorry, I have no idea what may cause that. Could you check if your SDR dongle is operational with rtl_test or gqrx?
Alex
Alex
Im a bit brain dead tonite…where is the rtl_test.exe located?
Todd
solved it…finally got outside to the antenna…wind blew it down!!!
sorry
Todd
Glad to hear that. The symptoms you described let me think that rtl-sdr have connected to the dongle but the radio samples the rtl-sdr receives from the dongle and passes to dump978 had no useful data, hence I asked you to check if the dongle is operational. The rtl_test is a part of the rtlsdr package, so you should be able to run it on the Linux box (looks like you are running Linux virtual machine). GQRX is a separate package you can install on the Linux box. GQRX analog on Windows is SDR#.
Alex
Thanks, Alex…I did figure out how to run rtl_test after a while…and it seemed to work
Todd
