The armbian os bookworm & trixie for OrangePiPC are done by Armbian “community” developers and may be they have configured gcc differently.
On the other hand the Armbian for Raspberry Pi are done by armbian’s “mainstream” developers, and dump1090-fa built on this distro do NOT give any issue. I have written to microSD card, the Armbian forky for RPi model 4, and both dump1090-fa and piaware work perfectly OK.
Following two packages I built on RPi Model 4 using Flightaware source-code both work normally
(1) Raspberry Pi OS trixie
gcc version 14.2.0 (Debian 14.2.0-19)
pi@rpios-trixie:~ $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/aarch64-linux-gnu/14/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 14.2.0-19' --with-bugurl=file:///usr/share/doc/gcc-14/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2,rust --prefix=/usr --with-gcc-major-version-only --program-suffix=-14 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/libexec --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-libstdcxx-backtrace --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-offload-targets=nvptx-none=/build/reproducible-path/gcc-14-14.2.0/debian/tmp-nvptx/usr --enable-offload-defaulted --without-cuda-driver --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=2
Thread model: posix
Supported LTO compression algorithms: zlib zstd
pi@rpios-trixie:~ $ dump1090-fa --version
| dump1090 ModeS Receiver dump1090-fa 10.2 |
| build options: ENABLE_RTLSDR ENABLE_BLADERF ENABLE_HACKRF ENABLE_LIMESDR |
detected runtime CPU features:
selected DSP implementations:
magnitude_uc8 neon_vrsqrte_armv8_neon_simd
magnitude_uc8_aligned neon_vrsqrte_armv8_neon_simd
magnitude_power_uc8 neon_vrsqrte_armv8_neon_simd
magnitude_power_uc8_aligned neon_vrsqrte_armv8_neon_simd
magnitude_sc16 neon_vrsqrte_armv8_neon_simd
magnitude_sc16_aligned neon_vrsqrte_armv8_neon_simd
magnitude_sc16q11 neon_vrsqrte_armv8_neon_simd
magnitude_sc16q11_aligned neon_vrsqrte_armv8_neon_simd
mean_power_u16 u32_armv8_neon_simd
mean_power_u16_aligned u32_armv8_neon_simd
count_above_u16 generic_armv8_neon_simd
count_above_u16_aligned generic_armv8_neon_simd_aligned
(2) Armbian OS forky for Raspberry Pi Model 4
gcc version 15.2.0 (Debian 15.2.0-12)
pi@armbian-forky:~$ cat /proc/cpuinfo | grep Model
Model : Raspberry Pi 4 Model B Rev 1.1
pi@armbian-forky:~$
pi@armbian-forky:~$ lsb_release -sc
forky
pi@armbian-forky:~$
pi@armbian-forky:~$ gcc -v
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/aarch64-linux-gnu/15/lto-wrapper
Configured with: ../src/configure -v --with-pkgversion='Debian 15.2.0-12' --with-bugurl=file:///usr/share/doc/gcc-15/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2,rust,cobol,algol68 --prefix=/usr --with-gcc-major-version-only --program-suffix=-15 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/libexec --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-libstdcxx-backtrace --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-offload-targets=nvptx-none=/build/reproducible-path/gcc-15-15.2.0/debian/tmp-nvptx/usr --enable-offload-defaulted --without-cuda-driver --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=4
Thread model: posix
pi@armbian-forky:~$ dump1090-fa --version
