Hello friends:
Indeed, as many of you have pointed out, the antenna’s height increase is barely noticeable on the horizon. I’ve been able to verify this over the past few days, even though I’ve been traveling, because I occasionally checked my TAR1090’s website.
According to @Socrammmfreitas’s table, and if my calculations are correct, the increase for an extra 2 meters is only about 500 meters.
Looking at the HTW line, the small increase in height is practically imperceptible.
Where have I noticed an improvement? To the North, Northwest, and South. Specifically, in areas where the antenna isn’t completely unobstructed.
For example, before I only covered half of Andorra; now I cover the entire country and part of the surrounding area. Coverage has also expanded to southern France, despite the Pyrenees, and another area “conquered” is the Valencia region, where I now have excellent coverage that wasn’t there before, and where I can now see many aircraft.
Also very important: Flights to, from, and over Ibiza. Previously almost impossible, but now it is.
The improvements described are indeed due to the increase in height, but for different reasons, such as being able to partially or totally avoid the height of some buildings towards those areas.
Is that why I’ve recently reached 15th place in the AirNav ranking for Spain?
It’s been a really interesting conversation. It started with my bad experience with the old cable, and I’ve ended up learning a lot.
By the way, the cable problem was solved by checking the connectors, although it sometimes fails, so it’s clear the problem is intermittent and most likely due to the same cable. I have a tester, but it broke, so I can’t check that.
I hope I have time to go shopping tomorrow the new cable (LMR400) for obvious reasons.
Thanks to everyone.
