SkyAware in Home Assistant: map, flight ETA, coverage chart and phone alerts
I’ve been feeding FlightAware for years and wanted my PiAware in Home Assistant, so I built a card and a small companion service: GitHub - jchisholm59/adsb-monitor: Always-on ADS-B monitor for PiAware + a Home Assistant SkyAware card: map, flight status & ETA, coverage polar chart, phone alerts for emergencies, military, helicopters and landings · GitHub
▎ - A map like SkyAware’s: range rings, altitude-coloured trails and aircraft shapes
▎ - A sortable aircraft list
▎ - A flight page with route, progress and estimated arrival
▎ - A coverage polar chart by altitude band, building up over time
▎ - Phone alerts for 7700/7600/7500 squawks, military aircraft or helicopters nearby, and a chosen flight landing at your local airport
▎ It reads SkyAware’s aircraft.json directly, needs no API keys, and setup is one .env file. The card installs through HACS (submitted to the default list); coverage and alerts need a small Node service anywhere on your LAN, such as the PiAware Pi itself. Feedback welcome.
Nice initiative, unfortunately I don’t use HA so I can’t check it out but it looks well thought through and the GitHub page is also well documented. Well done sir.
Thanks. Also this one..
You should install Home Assistant. Just added real-time cockpit views.
Well I’m using a different home control system (Domoticz) to cater to my needs. That’s quite extensive with a lot of routines and custom written scripts.
I don’t want to start over again :wink:
Fair enough! The cards need HA, but the monitor service is standalone and its alerts are a plain JSON webhook, if you ever want to wire it into Domoticz.
Created a new standalone version, no Home Assistant needed. See my latest announcement.
Thanks for the inspiration.
I’m going to check it out tomorrow evening and I’ll get back to you with my feedback :+1:t2:
